Datasheet AD650 (Analog Devices) - 2
DescriptionVoltage-to-Frequency and Frequency-to-Voltage Converter
Pages / Page21 / 2 — AD650* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
RevisionE
File Format / SizePDF / 454 Kb
AD650* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. DESIGN RESOURCES. DOCUMENTATION
AD650* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS DESIGN RESOURCES DOCUMENTATION
View a parametric search of comparable parts. • AD650 Material Declaration • PCN-PDN Information
DOCUMENTATION
• Quality And Reliability
Application Notes
• Symbols and Footprints • AN-276: Analog to Digital Conversion by Using V/F Converters
DISCUSSIONS
• AN-279: Using the AD650 Voltage-to-Frequency View all AD650 EngineerZone Discussions. Converter As a Frequency-to-Voltage Converter • AN-361: Ask the Applications Engineer (V/F Converters)
SAMPLE AND BUY Data Sheet
Visit the product page to see pricing options. • AD650: Voltage-to-Frequency and Frequency-to-Voltage Converter Data Sheet
TECHNICAL SUPPORT TOOLS AND SIMULATIONS
Submit a technical question or find your regional support number. • AD650 Component Selection Calculator
DOCUMENT FEEDBACK REFERENCE MATERIALS
Submit feedback for this data sheet.
Technical Articles
• DDS IC Plus Frequency-To-Voltage Converter Make Low- Cost DAC
Document Outline Features Functional Block Diagram Product Description Product Highlights Revision History Specifications Absolute Maximum Ratings ESD Caution Pin Configurations and Function Descriptions Circuit Operation Unipolar Configuration One-Shot Timing Component Selection Bipolar V/F Unipolar V/F, Negative Input Voltage F/V Conversion High Frequency Operation Decoupling and Grounding Temperature Coefficients Nonlinearity Specification PSRR Other Circuit Considerations Applications Differential Voltage-to-Frequency Conversion Autozero Circuit Phase-Locked Loop F/V Conversion Outline Dimensions Ordering Guide
