AMP03System DesignSuggested Op AmpAMP03E2RequirementFor A1 and A2 Source Impedance Low, Need Low OP27, OP37 Voltage Noise Performance OP227 (Dual Matched) RE OP270 (Dual) 1OP80EJ OP271 OP470 II0LOAD0 = ( E1 – E2 )/R OP471 Source Impedance High OP80 Figure 8. Differential Input Voltage-to-Current Converter (RS ≥ 15 kΩ). Need Low Current OP41 for Low IOUT. OP80EJ maintains 250 fA max input current, Noise OP43 allowing IO to be less than 1 pA. OP249 OP97 AMP03–IN E1A1 Require Ultrahigh Input Impedance OP80 R2 OP97 OP41 R1ER20 OUTPUT OP43 A2 Need Wider Bandwidth and High OP42 +IN E2 Speed OP43 OP249 E0 = (1 + 2R2/R1) (E2 – E1) Figure 9. Suitable Instrumentation Amplifier Requirements Can Be Addressed by Using an Input Stage Consisting of A1, A2, R1, and R2. The following matrix suggests a suitable amplifier. REV. F –7– Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM PIN CONNECTIONS SPECIFICATIONS WAFER TEST LIMITS ABSOLUTE MAXIMUM RATINGS ORDERING GUIDE DICE CHARACTERISTICS BURN-IN CIRCUIT SLEW RATE TEST CIRCUIT Typical Performance Characteristics APPLICATION CIRCUITS APPLICATIONS INFORMATION MAINTAINING COMMON-MODE REJECTION OUTLINE DIMENSIONS Revision History
