ADIS16465Preliminary Technical DataPIN CONFIGURATION AND FUNCTION DESCRIPTIONSADIS16465PIN 1TOP VIEW(Not to Scale)PIN 14KDDCCLNDGNVDNDNDISCDRCCCTCCSUTDNDNDNRSDOSYNNOTES 1. THIS REPRESENTS THE PIN ASSIGNMENTS WHENLOOKING DOWN AT THE CONNECTOR. SEE FIGURE 6.2. MATING CONNECTOR:SAMTEC CLM-107-02 SERIES OR EQUIVALENT. 005 006 38- 3. DNC = DO NOT CONNECT. 154 15438- Figure 6. Pin Assignments, Bottom View Figure 7. Pin Assignments, Package Level View Table 5. Pin Function Descriptions Pin No.MnemonicTypeDescription 1 DR Output Data Ready Indicator. 2 SYNC Input/Output External Sync Input/Output, per MSC_CTRL. See Error! Reference source not found. . 3 SCLK Input SPI Serial Clock. 4 DOUT Output SPI Data Output. This pin clocks the output on the SCLK falling edge. 5 DIN Input SPI Data Input. This pin clocks the input on the SCLK rising edge. 6 CS Input SPI Chip Select. 7 DNC Not applicable Do Not Connect. Do not connect to this pin. 8 RST Input Reset. 9 DNC Not applicable Do Not Connect. Do not connect to this pin. 10 DNC Not applicable Do Not Connect. Do not connect to this pin. 11 VDD Supply Power Supply. 12 DNC Not applicable Do Not Connect. Do not connect to this pin. 13 GND Supply Power Ground. 14 DNC Not applicable Do Not Connect. Do not connect to this pin. Rev. PrA | Page 8 of 32
