Datasheet ADIS16485 (Analog Devices) - 8
DescriptionTactical Grade Six Degrees of Freedom MEMS Inertial Sensor
Pages / Page32 / 8 — ADIS16485. Data Sheet. ABSOLUTE MAXIMUM RATINGS Table 4. Parameter …
RevisionH
File Format / SizePDF / 918 Kb
ADIS16485. Data Sheet. ABSOLUTE MAXIMUM RATINGS Table 4. Parameter Rating. Table 5. Package Characteristics. Device. Package Type
ADIS16485 Data Sheet ABSOLUTE MAXIMUM RATINGS Table 4 Parameter Rating Table 5 Package Characteristics Device Package Type
ADIS16485 Data Sheet ABSOLUTE MAXIMUM RATINGS Table 4.
Stresses at or above those listed under Absolute Maximum
Parameter Rating
Ratings may cause permanent damage to the product. This is a Acceleration stress rating only; functional operation of the product at these Any Axis, Unpowered 2000 g or any other conditions above those indicated in the operational Any Axis, Powered 2000 g section of this specification is not implied. Operation beyond VDD to GND −0.3 V to +3.6 V the maximum operating conditions for extended periods may Digital Input Voltage to GND −0.3 V to VDD + 0.2 V affect product reliability. Digital Output Voltage to GND −0.3 V to VDD + 0.2 V
Operating Temperature Range −40°C to +105°C
Device
Storage Temperature Range −65°C to +150°C1
Package Type θJA θJC Weight
1 Extended exposure to temperatures that are lower than −40°C or higher 24-Lead Module (ML-24-6) 22.8°C/W 10.1°C/W 48 g than +105°C can adversely affect the accuracy of the factory calibration.
ESD CAUTION
Rev. G | Page 8 of 32 Document Outline Features Applications General Description Functional Block Diagram Revision History Specifications Timing Specifications Timing Diagrams Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Basic Operation Register Structure SPI Communication Device Configuration Dual Memory Structure Reading Sensor Data User Registers Output Data Registers Inertial Sensor Data Format Rotation Rate (Gyroscope) Acceleration Delta Angles Delta Velocity Internal Temperature Status/Alarm Indicators Firmware Revision Product Identification Digital Signal Processing Gyroscopes/Accelerometers Averaging/Decimation Filter FIR Filter Banks Filter Memory Organization Default Filter Performance Calibration Gyroscopes Manual Bias Correction Bias Null Command Manual Sensitivity Correction Linear Acceleration on Effect on Gyroscope Bias Accelerometers Manual Bias Correction Manual Sensitivity Correction Restoring Factory Calibration Point of Percussion Alignment Alarms Static Alarm Use Dynamic Alarm Use Alarm Example System Controls Global Commands Software Reset Automatic Self Test Memory Management Flash Memory Test General-Purpose I/O Data-Ready Indicator Input Sync/Clock Control General-Purpose I/O Control Power Management General-Purpose Registers Real-Time Clock Configuration/Data Applications Information Mounting Tips Evaluation Tools Breakout Board, ADIS16IMU/PCBZ PC-Based Evaluation, EVAL-ADIS2 Power Supply Considerations Outline Dimensions Ordering Guide
