Datasheet ADIS16375 (Analog Devices)
DescriptionLow Profile, Low Noise Six Degrees of Freedom Inertial Sensor
Pages / Page29 / 1 — Low Profile, Low Noise. Six Degrees of Freedom Inertial Sensor. Data …
RevisionE
File Format / SizePDF / 795 Kb
Low Profile, Low Noise. Six Degrees of Freedom Inertial Sensor. Data Sheet. ADIS16375. FEATURES. FUNCTIONAL BLOCK DIAGRAM
Datasheet ADIS16375 Analog Devices, Revision: E
Low Profile, Low Noise Six Degrees of Freedom Inertial Sensor Data Sheet ADIS16375 FEATURES FUNCTIONAL BLOCK DIAGRAM Triaxis digital gyroscope, ±300°/sec TEMPERATURE Tight orthogonal alignment: 0.05° SENSOR Triaxis digital accelerometer: ±18 g TRIAXIS MEMS CS ANGULAR RATE Delta-angle/velocity calculations SENSOR SIGNAL CALIBRATION OUTPUT SCLK CONDITIONING REGISTERS Wide sensor bandwidth: 330 Hz AND AND DIGITAL AND SPI DIN CONVERSION INTERFACE High sample rate: 2.460 kSPS PROCESSING DOUT Autonomous operation and data collection TRIAXIS MEMS No external configuration commands required ACCELERATION SENSOR Startup time: 500 ms VDDRTC ALARMS Factory calibrated sensitivity, bias, and axial alignment POWER VCC Calibration temperature range: −40°C to +85°C MANAGEMENT DIGITAL SELF-TEST SPI-compatible serial interface CONTROL GND Embedded temperature sensor ADIS16375 Programmable operation and control
001
RST DIO1 DIO2 DIO3 DIO4 Automatic and manual bias correction controls
09389-
4 FIR filter banks, 120 configurable taps
Figure 1.
Digital I/O: data-ready, alarm indicator, external clock GENERAL DESCRIPTION Alarms for condition monitoring
The ADIS16375 iSensor® is a complete inertial system that includes
Power-down/sleep mode for power management
a triaxis gyroscope and triaxis accelerometer. Each sensor in the
Enable external sample clock input: up to 2.25 kHz
ADIS16375 combines industry-leading iMEMS® technology
Single-command self test Single-supply operation: 3.3 V
with signal conditioning that optimizes dynamic performance.
2000 g shock survivability
The factory calibration characterizes each sensor for sensitivity,
Operating temperature range: −40°C to +105°C
bias, alignment, and linear acceleration (gyro bias). As a result, each sensor has its own dynamic compensation formulas that provide accurate sensor measurements over a temperature
range of −40°C to +105°C.
Precision instrumentation
The ADIS16375 provides a simple, cost-effective method for
Platform stabilization and control
integrating accurate, multiaxis, inertial sensing into industrial
Industrial vehicle navigation
systems, especially when compared with the complexity and
Downhole instrumentation
investment associated with discrete designs. All necessary motion
Robotics
testing and calibration are part of the production process at the factory, greatly reducing system integration time. Tight orthogonal alignment simplifies inertial frame alignment in navigation systems. An improved SPI interface and register structure provide faster data col ection and configuration control. This compact module is approximately 44 mm × 47 mm × 14 mm and provides a flexible connector interface that enables multiple mounting orientation options.
Rev. D Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2010–2017 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline Features Applications Functional Block Diagram General Description Revision History Specifications Timing Specifications Timing Diagrams Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Basic Operation Register Structure SPI Communication Device Configuration Dual Memory Structure Reading Sensor Data User Registers Output Data Registers Inertial Sensor Data Format Rotation Rate (Gyroscope) Acceleration Delta Angles Velocity Changes Internal Temperature Status/Alarm Indicators Product Identification Digital Signal Processing Sampling Plan Averaging/Decimation Filter FIR Filter Banks Filter Memory Organization Default Filter Performance Calibration Manual Bias Correction Manual Sensitivity Correction Bias Null Command Restoring Factory Calibration Linear Acceleration on Effect on Gyroscope Bias Point of Percussion Alignment Alarms Static Alarm Use Dynamic Alarm Use Alarm Reporting Alarm Example System Controls Global Commands Software Reset Automatic Self Test Memory Management Flash Memory Test General-Purpose I/O Data-Ready Indicator Input Sync/Clock Control General-Purpose I/O Control Power Management Real-Time Clock Configuration/Data Applications Information Mounting Tips Evaluation Tools Breakout Board, ADIS16IMU/PCBZ PC-Based Evaluation, EVAL-ADIS2 Power Supply Considerations Outline Dimensions Ordering Guide
