ADIS16375* PRODUCT PAGE QUICK LINKS Last Content Update: 10/18/2017COMPARABLE PARTSREFERENCE MATERIALS View a parametric search of comparable parts. Solutions Bulletins & Brochures • Industrial ICs Solutions Bulletin, Volume 10, Issue 8 EVALUATION KITS • iSensor MEMS Inertial Measurement Unit (IMU) Brochure • Breakout Board for the ADIS1613x, ADIS1637x, ADIS1648x and ADIS1649x DESIGN RESOURCES • EVAL-ADIS Evaluation System • adis16375 Material Declaration • EVAL-ADIS2 Evaluation System • PCN-PDN Information • Quality And Reliability DOCUMENTATION • Symbols and Footprints Application Notes • AN-1295: Mechanical Design Tips for ADIS16375, DISCUSSIONS ADIS16480, ADIS16485, and ADIS16488 View all adis16375 EngineerZone Discussions. Data Sheet • ADIS16375: Anomaly Data Sheet SAMPLE AND BUY • ADIS16375: Low Profile, Low Noise Six Degrees of Visit the product page to see pricing options. Freedom Inertial Sensor Data Sheet User GuidesTECHNICAL SUPPORT • UG-287: EVAL-ADIS: iSensor Evaluation System Submit a technical question or find your regional support number. SOFTWARE AND SYSTEMS REQUIREMENTS • ADIS16480 IIO Inertial Measurement Unit Linux Driver DOCUMENT FEEDBACK Submit feedback for this data sheet. This page is dynamically generated by Analog Devices, Inc., and inserted into this data sheet. A dynamic change to the content on this page will not trigger a change to either the revision number or the content of the product data sheet. This dynamic page may be frequently modified. Document Outline Features Applications Functional Block Diagram General Description Revision History Specifications Timing Specifications Timing Diagrams Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Basic Operation Register Structure SPI Communication Device Configuration Dual Memory Structure Reading Sensor Data User Registers Output Data Registers Inertial Sensor Data Format Rotation Rate (Gyroscope) Acceleration Delta Angles Velocity Changes Internal Temperature Status/Alarm Indicators Product Identification Digital Signal Processing Sampling Plan Averaging/Decimation Filter FIR Filter Banks Filter Memory Organization Default Filter Performance Calibration Manual Bias Correction Manual Sensitivity Correction Bias Null Command Restoring Factory Calibration Linear Acceleration on Effect on Gyroscope Bias Point of Percussion Alignment Alarms Static Alarm Use Dynamic Alarm Use Alarm Reporting Alarm Example System Controls Global Commands Software Reset Automatic Self Test Memory Management Flash Memory Test General-Purpose I/O Data-Ready Indicator Input Sync/Clock Control General-Purpose I/O Control Power Management Real-Time Clock Configuration/Data Applications Information Mounting Tips Evaluation Tools Breakout Board, ADIS16IMU/PCBZ PC-Based Evaluation, EVAL-ADIS2 Power Supply Considerations Outline Dimensions Ordering Guide
