Datasheet ADIS16375 (Analog Devices) - 6
DescriptionLow Profile, Low Noise Six Degrees of Freedom Inertial Sensor
Pages / Page29 / 6 — Data Sheet. ADIS16375. Parameter. Test Conditions/Comments. Min. Typ. Max …
RevisionE
File Format / SizePDF / 795 Kb
Data Sheet. ADIS16375. Parameter. Test Conditions/Comments. Min. Typ. Max Unit
Data Sheet ADIS16375 Parameter Test Conditions/Comments Min Typ Max Unit
FLASH MEMORY Endurance4 100,000 Cycles Data Retention5 TJ = 85°C 20 Years FUNCTIONAL TIMES6 Time until data is available Power-On Startup Time 500 ms Reset Recovery Time 500 ms Sleep Mode Recovery Time 500 µs Flash Memory Update Time 375 ms Flash Memory Test Time 50 ms Automatic Self Test Time Using internal clock, 100 SPS 10 ms CONVERSION RATE 2.46 kSPS Initial Clock Accuracy 0.02 % Temperature Coefficient 40 ppm/°C Sync Input Clock 0.77 2.25 kHz POWER SUPPLY, VDD Operating voltage range 3.0 3.6 V Power Supply Current8 Normal mode, VDD = 3.3 V 173 mA Sleep mode, VDD = 3.3 V 12.3 mA Power-down mode, VDD = 3.3 V 120 µA POWER SUPPLY, VDDRTC Operating voltage range 3.3 V Real-Time Clock Supply Current Normal mode, VDDRTC = 3.3 V 13 µA 1 Each gyroscope and accelerometer has 32 bits of available resolution. The 16-bit sensitivity shown reflects the register that contains the upper 16 bits of the sensor output. Divide this number by 2 for every bit added to this resolution in downstream processing routines. 2 The digital I/O signals are driven by an internal 3.3 V supply, and the inputs are 5 V tolerant. 3 RST and CS pins are connected to the VDD pin through 10 kΩ pull-up resistors. 4 Endurance is qualified as per JEDEC Standard 22, Method A117, and measured at −40°C, +25°C, +85°C, and +125°C. 5 The data retention lifetime equivalent is at a junction temperature (TJ) of 85°C as per JEDEC Standard 22, Method A117. Data retention lifetime decreases with junction temperature. 6 These times do not include thermal settling and internal filter response times (330 Hz bandwidth), which may affect overal accuracy. 7 The 0.7 kHz lower limit is established to support Nyquist sampling criteria for the 330 Hz sensor bandwidth. 8 During startup, the power supply current increases and experiences transient behaviors for a period of 400 µs. The peak current during the 400 µs transient period can reach 1500 mA. Rev. D | Page 5 of 28 Document Outline Features Applications Functional Block Diagram General Description Revision History Specifications Timing Specifications Timing Diagrams Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Basic Operation Register Structure SPI Communication Device Configuration Dual Memory Structure Reading Sensor Data User Registers Output Data Registers Inertial Sensor Data Format Rotation Rate (Gyroscope) Acceleration Delta Angles Velocity Changes Internal Temperature Status/Alarm Indicators Product Identification Digital Signal Processing Sampling Plan Averaging/Decimation Filter FIR Filter Banks Filter Memory Organization Default Filter Performance Calibration Manual Bias Correction Manual Sensitivity Correction Bias Null Command Restoring Factory Calibration Linear Acceleration on Effect on Gyroscope Bias Point of Percussion Alignment Alarms Static Alarm Use Dynamic Alarm Use Alarm Reporting Alarm Example System Controls Global Commands Software Reset Automatic Self Test Memory Management Flash Memory Test General-Purpose I/O Data-Ready Indicator Input Sync/Clock Control General-Purpose I/O Control Power Management Real-Time Clock Configuration/Data Applications Information Mounting Tips Evaluation Tools Breakout Board, ADIS16IMU/PCBZ PC-Based Evaluation, EVAL-ADIS2 Power Supply Considerations Outline Dimensions Ordering Guide
