Datasheet ADIS16375 (Analog Devices) - 9
DescriptionLow Profile, Low Noise Six Degrees of Freedom Inertial Sensor
Pages / Page29 / 9 — ADIS16375. Data Sheet. PIN CONFIGURATION AND FUNCTION DESCRIPTIONS. TOP …
RevisionE
File Format / SizePDF / 795 Kb
ADIS16375. Data Sheet. PIN CONFIGURATION AND FUNCTION DESCRIPTIONS. TOP VIEW. (Not to Scale). IO4. DNC. IO2. IO1. IO3. DDRT V
ADIS16375 Data Sheet PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TOP VIEW (Not to Scale) IO4 DNC IO2 IO1 IO3 DDRT V
ADIS16375 Data Sheet PIN CONFIGURATION AND FUNCTION DESCRIPTIONS ADIS16375 TOP VIEW (Not to Scale) T UT ND DD DD IO4 DNC DNC DNC DNC DNC G V V RS CS DO D 24 22 20 18 16 14 12 10 8 6 4 2 23 21 19 17 15 13 11 9 7 5 3 1 C N K ND ND DD IO2 IO1 DI IO3 DNC DNC DNC G G V CL D D D S DDRT V NOTES 1. THIS REPRESENTATION DISPLAYS THE TOP VIEW PINOUT FOR THE MATING SOCKET CONNECTOR. 2. THE ACTUAL CONNECTOR PINS ARE NOT VISIBLE FROM THE TOP VIEW.
005
3. MATING CONNECTOR: SAMTEC CLM-112-02 OR EQUIVALENT. 4. DNC = DO NOT CONNECT.
09389- Figure 5. Mating Connector Pin Assignments 006
PIN 23 PIN 1
09389- Figure 6. Axial Orientation (Top Side Facing Up)
Table 5. Pin Function Descriptions Pin No. Mnemonic Type Description
1 DIO3 Input/Output Configurable Digital Input/Output. 2 DIO4 Input/Output Configurable Digital Input/Output. 3 SCLK Input SPI Serial Clock. 4 DOUT Output SPI Data Output. Clocks output on SCLK falling edge. 5 DIN Input SPI Data Input. Clocks input on SCLK rising edge. 6 CS Input SPI Chip Select. 7 DIO1 Input/Output Configurable Digital Input/Output. 8 RST Input Reset. 9 DIO2 Input/Output Configurable Digital Input/Output. 10, 11, 12 VDD Supply Power Supply. 13, 14, 15 GND Supply Power Ground. 16 to 22, 24 DNC Not applicable Do Not Connect. 23 VDDRTC Supply Real-Time Clock Power Supply. Rev. D | Page 8 of 28 Document Outline Features Applications Functional Block Diagram General Description Revision History Specifications Timing Specifications Timing Diagrams Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Basic Operation Register Structure SPI Communication Device Configuration Dual Memory Structure Reading Sensor Data User Registers Output Data Registers Inertial Sensor Data Format Rotation Rate (Gyroscope) Acceleration Delta Angles Velocity Changes Internal Temperature Status/Alarm Indicators Product Identification Digital Signal Processing Sampling Plan Averaging/Decimation Filter FIR Filter Banks Filter Memory Organization Default Filter Performance Calibration Manual Bias Correction Manual Sensitivity Correction Bias Null Command Restoring Factory Calibration Linear Acceleration on Effect on Gyroscope Bias Point of Percussion Alignment Alarms Static Alarm Use Dynamic Alarm Use Alarm Reporting Alarm Example System Controls Global Commands Software Reset Automatic Self Test Memory Management Flash Memory Test General-Purpose I/O Data-Ready Indicator Input Sync/Clock Control General-Purpose I/O Control Power Management Real-Time Clock Configuration/Data Applications Information Mounting Tips Evaluation Tools Breakout Board, ADIS16IMU/PCBZ PC-Based Evaluation, EVAL-ADIS2 Power Supply Considerations Outline Dimensions Ordering Guide
