Datasheet ADIS16364 (Analog Devices) - 2
DescriptionSix Degrees of Freedom Inertial Sensor
Pages / Page21 / 2 — ADIS16364* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
RevisionF
File Format / SizePDF / 397 Kb
ADIS16364* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. DESIGN RESOURCES. EVALUATION KITS
ADIS16364* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS DESIGN RESOURCES EVALUATION KITS
View a parametric search of comparable parts. • ADIS16364 Material Declaration • PCN-PDN Information
EVALUATION KITS
• Quality And Reliability • ADIS16IMU2 Breakout Board • Symbols and Footprints • EVAL-ADIS2 Evaluation System
DISCUSSIONS DOCUMENTATION
View all ADIS16364 EngineerZone Discussions.
Application Notes
• AN-1041: iSensor® IMU Quick Start Guide and Bias
SAMPLE AND BUY
Optimization Tips Visit the product page to see pricing options. • AN-1045: iSensor® IMU Mounting Tips
Data Sheet TECHNICAL SUPPORT
• ADIS16364: Anomaly Data Sheet Submit a technical question or find your regional support • ADIS16364: Six Degrees of Freedom Inertial Sensor Data number. Sheet
User Guides DOCUMENT FEEDBACK
• UG-363: ADISUSB User Guide Submit feedback for this data sheet.
SOFTWARE AND SYSTEMS REQUIREMENTS
• ADIS16400 IIO Inertial Measurement Unit Linux Driver • ADIS16400 IIO Inertial Measurement Unit Linux Driver • ADIS16334 and ADIS16360/2/4/5/7 Evaluation Software for the ADISUSB
This page is dynamically generated by Analog Devices, Inc., and inserted into this data sheet. A dynamic change to the content on this page will not trigger a change to either the revision number or the content of the product data sheet. This dynamic page may be frequently modified.
Document Outline Features Applications General Description Functional Block Diagram Revision History Specifications Timing Specifications Timing Diagrams Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Basic Operation Reading Sensor Data Device Configuration Memory Map Burst Read Data Collection Output Data Registers Calibration Manual Bias Calibration Gyroscope Automatic Bias Null Calibration Gyroscope Precision Automatic Bias Null Calibration Restoring Factory Calibration Linear Acceleration Bias Compensation (Gyroscope) Operational Control Global Commands Internal Sample Rate Power Management Sensor Bandwidth Digital Filtering Dynamic Range Input/Output Functions General-Purpose I/O Input Clock Configuration Data Ready I/O Indicator Auxiliary DAC Diagnostics Self-Test Memory Test Status Alarm Registers Product Identification Applications Information Installation/Handling Gyroscope Bias Optimization Input ADC Channel Interface Printed Circuit Board (PCB) Outline Dimensions Ordering Guide
