Datasheet ADIS16364 (Analog Devices)
DescriptionSix Degrees of Freedom Inertial Sensor
Pages / Page2 / 1 — Six Degrees of Freedom Sensor. Silicon Anomaly. ADIS16364. ADIS16364 …
File Format / SizePDF / 47 Kb
Six Degrees of Freedom Sensor. Silicon Anomaly. ADIS16364. ADIS16364 ANOMALIES. ANOMALY STATUS Reference Number. Description
Datasheet ADIS16364 Analog Devices
Six Degrees of Freedom Sensor Silicon Anomaly ADIS16364 ADIS16364 ANOMALIES
This anomaly list describes the known bugs, anomalies, and workarounds for the ADIS16364. Analog Devices, Inc., is committed, through future silicon revisions, to continuously improve silicon functionality. Analog Devices tries to ensure that these future silicon revisions remain compatible with your present software/systems by implementing the recommended workarounds outlined here.
ANOMALY STATUS Reference Number Description Status
er001 MSC_CTRL register programmed with incorrect default value Fixed
MSC_CTRL DEFAULT VALUE INCORRECT [er001] Background
The ADIS16365 offers a data ready option with either DIO1 or DIO2, depending on the setting in MSC_CTRL Bits[2:0].
Issue
The factory default setting for MSC_CTRL is 0x0006, which sets DIO1 as a positive pulse, data ready signal. For some parts with a date code earlier than 0918, the factory default value was 0x0000, which disables the data ready function on DIO1. This has been resolved, and all new parts have a factory default setting of 0x0006 for MSC_CTRL. In addition, after this error was discovered, all existing inventory was corrected.
Workaround
When the power supply reaches 4.75 V, wait 500 ms to ensure that the part has started up, and then set MSC_CTRL Bits[7:0] = 0x06 by writing DIN = 0xB406. Next, execute a manual flash update by writing DIN = 0xBE08 (GLOB_CMD Bit3 = 1). Wait 100 ms, and then the device will operate with DIO1 as a positive pulse, data ready signal, and the setting will be nonvolatile.
Related Issues
None.
Rev. 0 Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. rights of third parties that may result from its use. Specifications subject to change without notice. No license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 www.analog.com Trademarks and registered trademarks are the property of their respective owners. Fax: 781.461.3113 ©2009 Analog Devices, Inc. All rights reserved.
Document Outline ADIS16364 ANOMALIES ANOMALY STATUS MSC_CTRL DEFAULT VALUE INCORRECT [er001]
