Datasheet ADIS16137 (Analog Devices)
Description | ±1000°/Sec Precision Angular Rate Sensor |
Pages / Page | 21 / 1 — ±1000°/Sec Precision Angular. Rate Sensor. Data Sheet. ADIS16137. … |
Revision | A |
File Format / Size | PDF / 521 Kb |
±1000°/Sec Precision Angular. Rate Sensor. Data Sheet. ADIS16137. FEATURES. GENERAL DESCRIPTION
±1000°/Sec Precision Angular Rate Sensor Data Sheet ADIS16137 FEATURES GENERAL DESCRIPTION Digital gyroscope system, ±1000°/sec measurement range
The ADIS16137 iSensor® is a high performance, digital gyro-
In-run bias stability, 2.8°/hour
scope sensing system that operates autonomously and requires
Autonomous operation and data collection
no user configuration to produce accurate rate sensing data. It
No external configuration commands required
provides performance advantages with its low noise density,
Start-up time: 245 ms
wide bandwidth, and excel ent in-run bias stability, which enable
Sleep mode recovery: 2.5 ms
applications such as platform control, navigation, robotics, and
Factory calibrated sensitivity and bias
medical instrumentation.
Calibration temperature range: −40°C to +85°C
This sensor system combines industry leading iMEMS® technology
SPI-compatible serial interface
with signal conditioning that optimizes dynamic performance.
Wide bandwidth: 400 Hz
The factory calibration characterizes the entire sensor signal chain
Embedded temperature sensor
for sensitivity and bias over a temperature range of −40°C to +85°C.
Programmable operation and control
As a result, each ADIS16137 has its own unique correction
Automatic and manual bias correction controls
formulas to produce accurate measurements upon instal ation.
Digital filters: Bartlett FIR, average/decimation
For some systems, the factory calibration eliminates the need
Internal sample rate: up to 2048 SPS
for system level calibration and greatly simplifies it for others.
Digital I/O: data ready, alarm indicator, general-purpose Alarms for condition monitoring
The ADIS16137 provides data at rates of up to 2048 SPS and
Sleep mode for power management
offers an averaging/decimation filter structure for optimizing noise/
Enable input sync operation
bandwidth trade-offs. The serial peripheral interface (SPI) and
Single-supply operation: 4.75 V to 5.25 V
user register structure provide easy access to configuration controls
2000 g shock survivability
and calibrated sensor data for embedded processor platforms.
Operating temperature range: −40°C to +105°C
The 36 mm × 44 mm × 14 mm package provides four holes for
simple mechanical attachment, using M2 (or 2-56 standard size) machine screws along with a standard 24-lead, dual row, 1 mm
Precision instrumentation
pitch connector that supports electrical attachment to a printed
Platform stabilization and controls
circuit board (PCB) or cable system. It is package and pin
Industrial vehicle navigation
compatible with the ADIS16133, the ADIS16135, and the
Downhole instrumentation
ADIS16136.
Robotics FUNCTIONAL BLOCK DIAGRAM DIO1 DIO2 DIO3 DIO4/CLKIN RST VDD SELF-TEST I/O ALARMS POWER GND MANAGEMENT MEMS SENSOR USER CONTROLLER CONTROL REGISTERS CS TEMP SENSOR SCLK SPI CLOCK CALIBRATION PORT DIN OUTPUT DATA DOUT REGISTERS FILTER
001
ADIS16137
1854- 1 Figure 1.
Rev. A Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2013–2014 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline Features Applications General Description Functional Block Diagram Table of Contents Revision History Specifications Timing Specifications Timing Diagrams Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Reading Sensor Data Output Data Registers Rotation Rate (Gyroscope) Internal Temperature Device Configuration Dual Memory Structure User Registers Digital Processing Configuration Internal Sample Rate Input Clock Configuration Digital Filtering Averaging/Decimation Filter Calibration Automatic Bias Correction (Autonull) Manual Bias Correction Restoring Factory Calibration Alarms Static Alarm Use Dynamic Alarm Use Alarm Reporting Alarm Example System Controls Global Commands Software Reset Memory Management Checksum Test General-Purpose Input/Output Data Ready Input/Output Indicator Example Input/Output Configuration Automatic Self Test Power Management Status Product Identification Applications Information Power Supply Considerations Prototype Interface Board Installation Tips Packaging and Ordering Information Outline Dimensions Ordering Guide
