Datasheet ADXRS646 (Analog Devices) - 2
DescriptionHigh Stability, Low Noise Vibration Rejecting Yaw Rate Gyroscope
Pages / Page13 / 2 — ADXRS646* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
RevisionC
File Format / SizePDF / 595 Kb
ADXRS646* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. DESIGN RESOURCES. EVALUATION KITS
ADXRS646* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS DESIGN RESOURCES EVALUATION KITS
View a parametric search of comparable parts. • ADXRS646 Material Declaration • PCN-PDN Information
EVALUATION KITS
• Quality And Reliability • ADXRS646 Breakout Board • Symbols and Footprints
DOCUMENTATION DISCUSSIONS Data Sheet
View all ADXRS646 EngineerZone Discussions. • ADXRS646-DSCC: Military Data Sheet • ADXRS646-EP: Enhanced Product Data Sheet
SAMPLE AND BUY
• ADXRS646: High Stability, Low Noise Vibration Rejecting Visit the product page to see pricing options. Yaw Rate Gyroscope Data Sheet
User Guides TECHNICAL SUPPORT
• UG-314: Evaluating the ±250°/Sec, High Stability, Low Submit a technical question or find your regional support Noise, Vibration Rejecting Yaw Rate Gyroscope with number. Analog Output
DOCUMENT FEEDBACK REFERENCE MATERIALS
Submit feedback for this data sheet.
Technical Articles
• ADI Ups Ante in High-Precision MEMS Gyros • MS-2158: Gyro Mechanical Performance: The Most Important Parameter
This page is dynamically generated by Analog Devices, Inc., and inserted into this data sheet. A dynamic change to the content on this page will not trigger a change to either the revision number or the content of the product data sheet. This dynamic page may be frequently modified.
Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS RATE SENSITIVE AXIS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION SETTING BANDWIDTH TEMPERATURE OUTPUT AND CALIBRATION SUPPLY RATIOMETRICITY NULL ADJUSTMENT SELF-TEST FUNCTION CONTINUOUS SELF-TEST MODIFYING THE MEASUREMENT RANGE IMMUNITY TO VIBRATION OUTLINE DIMENSIONS ORDERING GUIDE
