Datasheet ADXRS646 (Analog Devices) - 5
DescriptionHigh Stability, Low Noise Vibration Rejecting Yaw Rate Gyroscope
Pages / Page13 / 5 — ADXRS646. Data Sheet. ABSOLUTE MAXIMUM RATINGS Table 2. Parameter Rating. …
RevisionC
File Format / SizePDF / 595 Kb
ADXRS646. Data Sheet. ABSOLUTE MAXIMUM RATINGS Table 2. Parameter Rating. RATE SENSITIVE AXIS. RATE. RATE OUT. AXIS. AVCC = 5V
ADXRS646 Data Sheet ABSOLUTE MAXIMUM RATINGS Table 2 Parameter Rating RATE SENSITIVE AXIS RATE RATE OUT AXIS AVCC = 5V
ADXRS646 Data Sheet ABSOLUTE MAXIMUM RATINGS Table 2.
Drops onto hard surfaces can cause shocks of greater than 10,000 g and can exceed the absolute maximum rating of the
Parameter Rating
device. Care should be exercised in handling to avoid damage. Acceleration (Any Axis, 0.5 ms) Unpowered 10,000 g
RATE SENSITIVE AXIS
Powered 10,000 g This is a Z-axis rate-sensing device (also called a yaw rate- VDD, AVCC −0.3 V to +6.6 V sensing device). It produces a positive going output voltage VRATIO AVCC for clockwise rotation about the axis normal to the package ST1, ST2 AVCC top, that is, clockwise when looking down at the package lid. Output Short-Circuit Duration Indefinite (Any Pin to Common) Operating Temperature Range −55°C to +125°C
RATE RATE OUT AXIS
Storage Temperature Range −65°C to +150°C
AVCC = 5V LONGITUDINAL 4.75V +
Stresses at or above those listed under Absolute Maximum Ratings
AXIS 7 VRATIO/2
may cause permanent damage to the product. This is a stress
RATE IN
rating only; functional operation of the product at these or any
1 A1 A B C D E F G 0.25V
other conditions above those indicated in the operational section of 002 1-
GND
this specification is not implied. Operation beyond the maximum
LATERAL AXIS
977 0 operating conditions for extended periods may affect product Figure 2. RATEOUT Signal Increases with Clockwise Rotation reliability.
ESD CAUTION
Rev. C | Page 4 of 12 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS RATE SENSITIVE AXIS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION SETTING BANDWIDTH TEMPERATURE OUTPUT AND CALIBRATION SUPPLY RATIOMETRICITY NULL ADJUSTMENT SELF-TEST FUNCTION CONTINUOUS SELF-TEST MODIFYING THE MEASUREMENT RANGE IMMUNITY TO VIBRATION OUTLINE DIMENSIONS ORDERING GUIDE
