Datasheet ADXRS642 (Analog Devices) - 5
DescriptionVibration Rejecting ±250°/s Yaw Rate Gyro
Pages / Page13 / 5 — ADXRS642. Data Sheet. ABSOLUTE MAXIMUM RATINGS Table 2. RATE SENSITIVE …
File Format / SizePDF / 353 Kb
ADXRS642. Data Sheet. ABSOLUTE MAXIMUM RATINGS Table 2. RATE SENSITIVE AXIS. Parameter Rating. RATE. RATE OUT. AXIS. VCC = 5V
ADXRS642 Data Sheet ABSOLUTE MAXIMUM RATINGS Table 2 RATE SENSITIVE AXIS Parameter Rating RATE RATE OUT AXIS VCC = 5V
ADXRS642 Data Sheet ABSOLUTE MAXIMUM RATINGS Table 2. RATE SENSITIVE AXIS Parameter Rating
This is a z-axis rate-sensing device (also called a yaw rate- Acceleration (Any Axis, 0.5 ms) sensing device). It produces a positive going output voltage Unpowered 10,000 g for clockwise rotation about the axis normal to the package Powered 10,000 g top, that is, clockwise when looking down at the package lid. VDD, AVCC −0.3 V to +6.0 V VRATIO AVCC
RATE RATE OUT
ST1, ST2 AVCC
AXIS
Output Short-Circuit Duration Indefinite
VCC = 5V
(Any Pin to Common)
LONGITUDINAL 4.75V AXIS +
Operating Temperature Range −55°C to +125°C
V 7 RATIO/2
Storage Temperature Range −65°C to +150°C
RATE IN 1
Stresses above those listed under the Absolute Maximum
A B C D E F G 0.25V A1
02 -0 Ratings may cause permanent damage to the device. This is a 770
LATERAL AXIS GND
09 stress rating only; functional operation of the device at these or Figure 2. RATEOUT Signal Increases with Clockwise Rotation any other conditions above those indicated in the operational section of this specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect
ESD CAUTION
device reliability. Drops onto hard surfaces can cause shocks of greater than 10,000 g and can exceed the absolute maximum rating of the device. Care should be exercised in handling to avoid damage. Rev. A | Page 4 of 12 Document Outline Features Applications General Description Functional Block Diagram Revision History Specifications Absolute Maximum Ratings Rate Sensitive Axis ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Setting Bandwidth Temperature Output and Calibration Supply Ratiometricity Modifying the Measurement Range Null Adjustment Self-Test Function Continuous Self-Test Mechanical Performance Outline Dimensions Ordering Guide
