Datasheet ADIS16135 (Analog Devices)
Description | ±300°/Sec Precision Angular Rate Sensor |
Pages / Page | 21 / 1 — ±300°/Sec. Precision Angular Rate Sensor. Data Sheet. ADIS16135. … |
Revision | F |
File Format / Size | PDF / 590 Kb |
±300°/Sec. Precision Angular Rate Sensor. Data Sheet. ADIS16135. FEATURES. GENERAL DESCRIPTION
±300°/Sec Precision Angular Rate Sensor Data Sheet ADIS16135 FEATURES GENERAL DESCRIPTION Digital gyroscope system, ±300°/sec measurement range
The ADIS16135 iSensor® is a high performance, digital gyro-
In-run bias stability, ~6°/hour
scope sensing system that operates autonomously and requires
~11°/hour over temperature: −40°C to +85°C
no user configuration to produce accurate rate sensing data. It
Autonomous operation and data collection
provides performance advantages with low noise density, wide
No external configuration commands required
bandwidth, and excel ent in-run bias stability, which are enabling
Start-up time: 181 ms; sleep mode recovery: 5 ms
for applications such as platform control, navigation, robotics,
Factory-calibrated sensitivity and bias
and medical instrumentation.
Calibration temperature range: −40°C to +85°C Single serial peripheral interface, SPI compatible
This sensor system combines industry-leading iMEMS® tech-
Wide bandwidth: 335 Hz
nology with signal conditioning that optimizes dynamic
Embedded temperature sensor
performance. The factory calibration characterizes the entire
Programmable operation and control
sensor signal chain for sensitivity and bias over a temperature
Automatic and manual bias correction controls
range of −40°C to +85°C. As a result, each ADIS16135 has its
Digital filters: Bartlett FIR, average/decimation
own unique correction formulas to produce accurate measure-
Internal sample rate: up to 2048 SPS
ments upon instal ation. For some systems, the factory calibration
Digital I/O: data ready, alarm indicator, general-purpose
eliminates the need for system-level calibration and greatly
Alarms for condition monitoring
simplifies it for others.
Sleep mode for power management
The ADIS16135 samples data at rates of up to 2048 SPS and
Enable external sample clock input: up to 2048 Hz
offers an averaging/decimation filter structure for optimizing
Single-supply operation: 4.85 V to 5.15 V
noise/bandwidth trade-offs. The serial peripheral interface (SPI)
2000 g shock survivability
and user register structure provide easy access to configuration
Operating temperature range: −40°C to +105°C
controls and calibrated sensor data for embedded processor
platforms.
Precision instrumentation
The 36 mm × 44 mm × 14 mm package provides four holes for
Platform stabilization and control
simple mechanical attachment, using M2 (or 2-56 standard size)
Industrial vehicle navigation
machine screws along with a standard 24-pin, dual-row, 1 mm
Downhole instrumentation
pitch connector that supports electrical attachment to a printed
Robotics
circuit board or cable system. The ADIS16135 provides an operating temperature range of −40°C to +105°C.
FUNCTIONAL BLOCK DIAGRAM DIO1 DIO2 CLKIN RST VCC SELF-TEST I/O ALARMS POWER GND MANAGEMENT MEMS SENSOR USER CONTROLLER CONTROL REGISTERS CS TEMP SENSOR SCLK SPI CLOCK CALIBRATION PORT DIN OUTPUT DATA DOUT REGISTERS FILTER
001
ADIS16135
08888- Figure 1.
Rev. F Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. Tel: 781.329.4700 ©2010–2014 Analog Devices, Inc. All rights reserved. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline Features Applications General Description Functional Block Diagram Revision History Specifications Timing Specifications Timing Diagrams Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Basic Operation Reading Sensor Data Output Data Registers Rotation Rate (Gyroscope) Internal Temperature Dual Memory Structure User Registers Digital Processing Configuration Internal Sample Rate Input Clock Configuration Digital Filtering Averaging/Decimation Filter Calibration Automatic Bias Correction Manual Bias Correction Alarms Static Alarm Use Dynamic Alarm Use Alarm Reporting Alarm Example System Controls Global Commands Software Reset Memory Management Checksum Test General-Purpose I/O Data Ready I/O Indicator Example I/O Configuration Self-Test Power Management Status Product Identification Applications Information Breakout Board Installation Tips Outline Dimensions Ordering Guide
