Datasheet ADIS16135 (Analog Devices) - 2
Description±300°/Sec Precision Angular Rate Sensor
Pages / Page21 / 2 — ADIS16135* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
RevisionF
File Format / SizePDF / 590 Kb
ADIS16135* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. DESIGN RESOURCES. EVALUATION KITS
ADIS16135* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS DESIGN RESOURCES EVALUATION KITS
View a parametric search of comparable parts. • ADIS16135 Material Declaration • PCN-PDN Information
EVALUATION KITS
• Quality And Reliability • Breakout Board for the ADIS1613x, ADIS1637x, ADIS1648x • Symbols and Footprints and ADIS1649x • EVAL-ADIS Evaluation System
DISCUSSIONS
View all ADIS16135 EngineerZone Discussions.
DOCUMENTATION Data Sheet SAMPLE AND BUY
• ADIS16135: ±300°/Sec Precision Angular Rate Sensor Data Visit the product page to see pricing options. Sheet
TECHNICAL SUPPORT SOFTWARE AND SYSTEMS REQUIREMENTS
Submit a technical question or find your regional support • ADIS16136 IIO Inertial Measurement Unit Linux Driver number. • IMU Evaluation Software for the EVAL-ADISx Platforms • USB Driver File for EVAL-ADISx Platforms (v2.2.95.68,
DOCUMENT FEEDBACK
3/9/2016) Submit feedback for this data sheet.
This page is dynamically generated by Analog Devices, Inc., and inserted into this data sheet. A dynamic change to the content on this page will not trigger a change to either the revision number or the content of the product data sheet. This dynamic page may be frequently modified.
Document Outline Features Applications General Description Functional Block Diagram Revision History Specifications Timing Specifications Timing Diagrams Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Basic Operation Reading Sensor Data Output Data Registers Rotation Rate (Gyroscope) Internal Temperature Dual Memory Structure User Registers Digital Processing Configuration Internal Sample Rate Input Clock Configuration Digital Filtering Averaging/Decimation Filter Calibration Automatic Bias Correction Manual Bias Correction Alarms Static Alarm Use Dynamic Alarm Use Alarm Reporting Alarm Example System Controls Global Commands Software Reset Memory Management Checksum Test General-Purpose I/O Data Ready I/O Indicator Example I/O Configuration Self-Test Power Management Status Product Identification Applications Information Breakout Board Installation Tips Outline Dimensions Ordering Guide
