Datasheet ADIS16080 (Analog Devices) - 2
Description±80°/sec Yaw Rate Gyro with SPI Interface
Pages / Page17 / 2 — ADIS16080* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
RevisionC
File Format / SizePDF / 579 Kb
ADIS16080* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. DESIGN RESOURCES. EVALUATION KITS
ADIS16080* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS DESIGN RESOURCES EVALUATION KITS
View a parametric search of comparable parts. • ADIS16080 Material Declaration • PCN-PDN Information
EVALUATION KITS
• Quality And Reliability • ADIS16080 Daughter Board • Symbols and Footprints • ADISUSB Evaluation System
DISCUSSIONS DOCUMENTATION
View all ADIS16080 EngineerZone Discussions.
Application Notes
• AN-1049: Calibrating iMEMS® Gyroscopes
SAMPLE AND BUY
• AN-918: Motionless Bandwidth Test for MEMS Sensors Visit the product page to see pricing options. • AN-942: Optimizing MEMS Gyroscope Performance with Digital Control
TECHNICAL SUPPORT Data Sheet
Submit a technical question or find your regional support • ADIS16080: ±80°/sec Yaw Rate Gyroscope with SPI Data number. Sheet
DOCUMENT FEEDBACK SOFTWARE AND SYSTEMS REQUIREMENTS
Submit feedback for this data sheet. • ADIS16080 IIO Yaw Rate Gyroscope Linux Driver
Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS TIMING SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION SUPPLY AND COMMON CONSIDERATIONS INCREASING MEASUREMENT RANGE SETTING BANDWIDTH SELF-TEST FUNCTION CONTINUOUS SELF-TEST RATE SENSITIVE AXIS BASIC OPERATION SERIAL PERIPHERAL INTERFACE (SPI) Control Register ADC Conversion Output Data Access Output Coding Examples APPLICATIONS INFORMATION ASSEMBLY INTERFACE BOARD OUTLINE DIMENSIONS ORDERING GUIDE
