Datasheet ADIS16080 (Analog Devices) - 7
Description±80°/sec Yaw Rate Gyro with SPI Interface
Pages / Page17 / 7 — ADIS16080. ABSOLUTE MAXIMUM RATINGS. Table 3. Parameter Rating. ESD …
RevisionC
File Format / SizePDF / 579 Kb
ADIS16080. ABSOLUTE MAXIMUM RATINGS. Table 3. Parameter Rating. ESD CAUTION
ADIS16080 ABSOLUTE MAXIMUM RATINGS Table 3 Parameter Rating ESD CAUTION
ADIS16080 ABSOLUTE MAXIMUM RATINGS Table 3.
Stresses above those listed under the Absolute Maximum
Parameter Rating
Ratings may cause permanent damage to the device. This is a Acceleration (Any Axis, Unpowered, 0.5 ms) 2000 g stress rating only; functional operation of the device at these or Acceleration (Any Axis, Powered, 0.5 ms) 2000 g any other conditions above those indicated in the operational V section of this specification is not implied. Exposure to absolute CC to COM −0.3 V to +6.0 V V maximum rating conditions for extended periods may affect DRIVE to COM −0.3 V to VCC + 0.3 V device reliability. Analog Input Voltage to COM −0.3 V to VCC + 0.3 V Digital Input Voltage to COM −0.3 V to +7.0 V Drops onto hard surfaces can cause shocks of greater than Digital Output Voltage to COM −0.3 V to VCC + 0.3 V 2000 g and exceed the absolute maximum rating of the device. ST1/ST2 Input Voltage to COM −0.3 V to VCC + 0.3 V Care should be exercised in handling to avoid damage. Operating Temperature Range −55°C to +125°C Storage Temperature Range −65°C to +150°C
ESD CAUTION
Rev. $ | Page 6 of 16 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS TIMING SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION SUPPLY AND COMMON CONSIDERATIONS INCREASING MEASUREMENT RANGE SETTING BANDWIDTH SELF-TEST FUNCTION CONTINUOUS SELF-TEST RATE SENSITIVE AXIS BASIC OPERATION SERIAL PERIPHERAL INTERFACE (SPI) Control Register ADC Conversion Output Data Access Output Coding Examples APPLICATIONS INFORMATION ASSEMBLY INTERFACE BOARD OUTLINE DIMENSIONS ORDERING GUIDE
