Datasheet AD8450 (Analog Devices) - 6
DescriptionPrecision Analog Front End and Controller for Battery Test/Formation Systems
Pages / Page42 / 6 — Data Sheet. AD8450. Parameter. Test Conditions/Comments. Min. Typ. Max. …
Data Sheet. AD8450. Parameter. Test Conditions/Comments. Min. Typ. Max. Unit
Data Sheet AD8450 Parameter Test Conditions/Comments Min Typ Max Unit
Small Signal −3 dB Bandwidth Gain = 0.2 420 kHz Gain = 0.27 730 kHz Gain = 0.4 940 kHz Gain = 0.8 1000 kHz Slew Rate 0.8 V/µs CONSTANT CURRENT AND CONSTANT VOLTAGE LOOP FILTER AMPLIFIERS Offset Voltage 150 µV Offset Voltage Drift TA = TMIN to TMAX 0.6 µV/°C Input Bias Current −5 +5 nA Over Temperature TA = TMIN to TMAX −5 +5 nA Input Common-Mode Voltage Range AVEE + 1.5 AVCC − 1.8 V Output Voltage Swing VVCLN = AVEE + 1 V, VVCLP = AVCC − 1 V AVEE + 1.5 AVCC − 1 V Over Temperature TA = TMIN to TMAX AVEE + 1.7 AVCC − 1 V Closed-Loop Output Impedance 0.01 Ω Capacitive Load Drive 1000 pF Source Short-Circuit Current 1 mA Sink Short-Circuit Current 40 mA Open-Loop Gain 140 dB CMRR ΔVCM = 10 V 100 dB PSRR ΔVS = 20 V 100 dB Voltage Noise f = 1 kHz 10 nV/√Hz Voltage Noise, Peak-to-Peak f = 0.1 Hz to 10 Hz 0.3 µV p-p Current Noise f = 1 kHz 80 fA/√Hz Current Noise, Peak-to-Peak f = 0.1 Hz to 10 Hz 5 pA p-p Small Signal Gain Bandwidth Product 3 MHz Slew Rate ΔVVINT = 10 V 1 V/μs CC to CV Transition Time 1.5 µs UNCOMMITTED OP AMP Offset Voltage 150 µV Offset Voltage Drift TA = TMIN to TMAX 0.6 µV/°C Input Bias Current −5 +5 nA Over Temperature TA = TMIN to TMAX −5 +5 nA Input Common-Mode Voltage Range AVEE + 1.5 AVCC − 1.8 V Output Voltage Swing AVEE + 1.5 AVCC − 1.5 V Over Temperature TA = TMIN to TMAX AVEE + 1.7 AVCC − 1.5 V Closed-Loop Output Impedance 0.01 Ω Capacitive Load Drive 1000 pF Short-Circuit Current 40 mA Open-Loop Gain RL = 2 kΩ 140 dB CMRR ΔVCM = 10 V 100 dB PSRR ΔVS = 20 V 100 dB Voltage Noise f = 1 kHz 10 nV/√Hz Voltage Noise, Peak-to-Peak f = 0.1 Hz to 10 Hz 0.3 µV p-p Current Noise f = 1 kHz 80 fA/√Hz Current Noise, Peak-to-Peak f = 0.1 Hz to 10 Hz 5 pA p-p Small Signal Gain Bandwidth Product 3 MHz Slew Rate ΔVOAVO = 10 V 1 V/µs Rev. B | Page 5 of 41 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS PGIA CHARACTERISTICS PGDA CHARACTERISTICS CC AND CV LOOP FILTER AMPLIFIERS, UNCOMMITTED OP AMP, AND VSET BUFFER VINT BUFFER CURRENT SHARING AMPLIFIER COMPARATORS REFERENCE CHARACTERISTICS THEORY OF OPERATION INTRODUCTION PROGRAMMABLE GAIN INSTRUMENTATION AMPLIFIER (PGIA) Gain Selection Reversing Polarity When Charging and Discharging PGIA Offset Option Battery Reversal and Overvoltage Protection PROGRAMMABLE GAIN DIFFERENCE AMPLIFIER (PGDA) CC AND CV LOOP FILTER AMPLIFIERS COMPENSATION VINT BUFFER MODE PIN, CHARGE AND DISCHARGE CONTROL OVERCURRENT AND OVERVOLTAGE COMPARATORS CURRENT SHARING BUS AND IMAX OUTPUT APPLICATIONS INFORMATION FUNCTIONAL DESCRIPTION POWER SUPPLY CONNECTIONS POWER SUPPLY SEQUENCING POWER-ON SEQUENCE POWER-OFF SEQUENCE PGIA CONNECTIONS Current Sensors Optional Low-Pass Filter PGDA CONNECTIONS Reverse Battery Conditions BATTERY CURRENT AND VOLTAGE CONTROL INPUTS (ISET AND VSET) LOOP FILTER AMPLIFIERS CONNECTING TO A PWM CONTROLLER (VCTRL PIN) OVERVOLTAGE AND OVERCURRENT COMPARATORS STEP BY STEP DESIGN EXAMPLE Step 1: Design the Switching Power Converter Step 2: Identify the Control Voltage Range of the ADP1972 Step 3: Determine the Control Voltage for the CV Loop and the PGDA Gain Step 4: Determine the Control Voltage for the CC Loop, the Shunt Resistor, and the PGIA Gain Step 5: Choose the Control Voltage Sources Step 6: Select the Compensation Devices ADDITIONAL INFORMATION EVALUATION BOARD INTRODUCTION FEATURES AND TESTS TESTING THE AD8450-EVALZ PGIA and Offset PGIA Gain Test PGIA in an Application Simple Offset Test Offset in an Application PGDA and Offset Simple Test PGDA in an Application PGDA Offset Overload Comparators VSET Buffer CV and CC Loop Filter Amplifiers CC and CV Integrator Tests Uncommitted Op Amp USING THE AD8450 SCHEMATIC AND ARTWORK OUTLINE DIMENSIONS ORDERING GUIDE
