Datasheet AD8450 (Analog Devices) - 8
DescriptionPrecision Analog Front End and Controller for Battery Test/Formation Systems
Pages / Page42 / 8 — Data Sheet. AD8450. Parameter. Test Conditions/Comments. Min. Typ. Max. …
RevisionB
Data Sheet. AD8450. Parameter. Test Conditions/Comments. Min. Typ. Max. Unit
Data Sheet AD8450 Parameter Test Conditions/Comments Min Typ Max Unit
Fault Output Logic Levels FAULT pin (Pin 46) Output Voltage High, VOH ILOAD = 200 µA 4.5 V Output Voltage Low, VOL ILOAD = 200 µA 0.5 V Propagation Delay CLOAD = 10 pF 500 ns Fault Rise Time CLOAD = 10 pF 150 ns Fault Fall Time CLOAD = 10 pF 150 ns VOLTAGE REFERENCE Nominal Output Voltage With respect to AGND 2.5 V Output Voltage Error ±1 % Temperature Drift TA = TMIN to TMAX 10 ppm/°C Line Regulation ΔVS = 10 V 40 ppm/V Load Regulation ΔIVREF = 1 mA (source only) 400 ppm/mA Output Current, Sourcing 10 mA Voltage Noise f = 1 kHz 100 nV/√Hz Voltage Noise, Peak-to-Peak f = 0.1 Hz to 10 Hz 5 µV p-p DIGITAL INTERFACE, MODE INPUT MODE pin (Pin 39) Input Voltage High, VIH With respect to DGND 2.0 DVCC V Input Voltage Low, VIL With respect to DGND DGND 0.8 V Mode Switching Time 500 ns POWER SUPPLY Operating Voltage Range AVCC 5 36 V AVEE −31 0 V Analog Supply Range AVCC − AVEE 5 36 V DVCC 3 5 V Quiescent Current AVCC 7 10 mA AVEE 6.5 10 mA DVCC 40 70 µA TEMPERATURE RANGE For Specified Performance −40 +85 °C Operational −55 +125 °C Rev. B | Page 7 of 41 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS PGIA CHARACTERISTICS PGDA CHARACTERISTICS CC AND CV LOOP FILTER AMPLIFIERS, UNCOMMITTED OP AMP, AND VSET BUFFER VINT BUFFER CURRENT SHARING AMPLIFIER COMPARATORS REFERENCE CHARACTERISTICS THEORY OF OPERATION INTRODUCTION PROGRAMMABLE GAIN INSTRUMENTATION AMPLIFIER (PGIA) Gain Selection Reversing Polarity When Charging and Discharging PGIA Offset Option Battery Reversal and Overvoltage Protection PROGRAMMABLE GAIN DIFFERENCE AMPLIFIER (PGDA) CC AND CV LOOP FILTER AMPLIFIERS COMPENSATION VINT BUFFER MODE PIN, CHARGE AND DISCHARGE CONTROL OVERCURRENT AND OVERVOLTAGE COMPARATORS CURRENT SHARING BUS AND IMAX OUTPUT APPLICATIONS INFORMATION FUNCTIONAL DESCRIPTION POWER SUPPLY CONNECTIONS POWER SUPPLY SEQUENCING POWER-ON SEQUENCE POWER-OFF SEQUENCE PGIA CONNECTIONS Current Sensors Optional Low-Pass Filter PGDA CONNECTIONS Reverse Battery Conditions BATTERY CURRENT AND VOLTAGE CONTROL INPUTS (ISET AND VSET) LOOP FILTER AMPLIFIERS CONNECTING TO A PWM CONTROLLER (VCTRL PIN) OVERVOLTAGE AND OVERCURRENT COMPARATORS STEP BY STEP DESIGN EXAMPLE Step 1: Design the Switching Power Converter Step 2: Identify the Control Voltage Range of the ADP1972 Step 3: Determine the Control Voltage for the CV Loop and the PGDA Gain Step 4: Determine the Control Voltage for the CC Loop, the Shunt Resistor, and the PGIA Gain Step 5: Choose the Control Voltage Sources Step 6: Select the Compensation Devices ADDITIONAL INFORMATION EVALUATION BOARD INTRODUCTION FEATURES AND TESTS TESTING THE AD8450-EVALZ PGIA and Offset PGIA Gain Test PGIA in an Application Simple Offset Test Offset in an Application PGDA and Offset Simple Test PGDA in an Application PGDA Offset Overload Comparators VSET Buffer CV and CC Loop Filter Amplifiers CC and CV Integrator Tests Uncommitted Op Amp USING THE AD8450 SCHEMATIC AND ARTWORK OUTLINE DIMENSIONS ORDERING GUIDE
