Datasheet CD4070BMS, CD4077BMS (Intersil) - 7
ManufacturerIntersil
DescriptionCMOS Quad Exclusive OR and Exclusive NOR Gates
Pages / Page8 / 7 — Typical Performance Characteristics. AMBIENT TEMPERATURE (TA) = +25oC. A) …
Revision2017-12-22
File Format / SizePDF / 271 Kb
Typical Performance Characteristics. AMBIENT TEMPERATURE (TA) = +25oC. A) (m. 15.0. (IOL). GATE-TO-SOURCE VOLTAGE (VGS) = 15V
Typical Performance Characteristics AMBIENT TEMPERATURE (TA) = +25oC A) (m 15.0 (IOL) GATE-TO-SOURCE VOLTAGE (VGS) = 15V
Typical Performance Characteristics AMBIENT TEMPERATURE (TA) = +25oC AMBIENT TEMPERATURE (TA) = +25oC A) (m 30 15.0 (IOL) GATE-TO-SOURCE VOLTAGE (VGS) = 15V T T (IOL) (mA) N N GATE-TO-SOURCE VOLTAGE (VGS) = 15V 25 12.5 RRE CU 20 10.0 10V SINK) CURRE (SINK) 15 7.5 10V OW L 10 LOW ( 5.0 TPUT 5 U 2.5 5V OUTPUT O 5V 0 5 10 15 0 5 10 15 DRAIN-TO-SOURCE VOLTAGE (VDS) (V) DRAIN-TO-SOURCE VOLTAGE (VDS) (V) FIGURE 3. TYPICAL OUTPUT LOW (SINK) CURRENT FIGURE 4. MINIMUM OUTPUT LOW (SINK) CURRENT CHARACTERISTICS CHARACTERISTICS DRAIN-TO-SOURCE VOLTAGE (VDS) (V) DRAIN-TO-SOURCE VOLTAGE (VDS) (V) -15 -10 -5 0 -15 -10 -5 0 0 0 AMBIENT TEMPERATURE (TA) = +25oC A) AMBIENT TEMPERATURE (TA) = +25oC A) GATE-TO-SOURCE VOLTAGE (VGS) = -5V -5 (m GATE-TO-SOURCE VOLTAGE (VGS) = -5V (m -10 (IOH) (IOH) T -5 T N N -15 RRE RRE -10V ) CU -10V ) CU -20 CE -10 UR -25 O (S SOURCE -15V -15V -30 IGH -15 H HIGH ( UT TP OU OUTPUT FIGURE 5. TYPICAL OUTPUT HIGH (SOURCE) CURRENT FIGURE 6. MINIMUM OUTPUT HIGH (SOURCE) CURRENT CHARACTERISTICS CHARACTERISTICS ) AMBIENT TEMPERATURE (T ns AMBIENT TEMPERATURE (T A) = +25oC A) = +25oC ( H) L (ns) P , t 300 HL 200 tTLH) tP ( E IM (tTHL, SUPPLY VOLTAGE (VDD) = 5V 150 E 200 Y T SUPPLY VOLTAGE (VDD) = 5V IM T ON 100 ITI 10V ION DELA 100 S 10V T N 15V 50 AGA TRA 15V OP R P 00 20 40 60 80 100 0 20 40 60 80 100 LOAD CAPACITANCE (CL) (pF) LOAD CAPACITANCE (CL) (pF) FIGURE 7. TYPICAL TRANSITION TIME AS A FUNCTION OF FIGURE 8. TYPICAL PROPAGATION DELAY TIME AS A LOAD CAPACITANCE FUNCTION OF LOAD CAPACITANCE
FN3322 Rev 0.00 Page 7 of 8 December 1992
