Datasheet EL817 (Everlight)
ManufacturerEverlight
Description4 Pin DIP Phototransistor Photocoupler
Pages / Page13 / 1 — 4 PIN DIP PHOTOTRANSISTOR PHOTOCOUPLER. EL817 Series. Features:. …
File Format / SizePDF / 846 Kb
4 PIN DIP PHOTOTRANSISTOR PHOTOCOUPLER. EL817 Series. Features:. Description. Applications
Datasheet EL817 Everlight
4 PIN DIP PHOTOTRANSISTOR PHOTOCOUPLER EL817 Series
Schematic
Features:
Current transfer ratio Pin Configuration (CTR: 50~600% at I 1. Anode F = 5mA, VCE = 5V)
High isolation voltage between input 2. Cathode and output (Viso = 5000Vrms) 3. Emitter
Creepage distance > 7.62mm 4. Collector
Operating temperature up to +110°C
Compact small outline package
The product itself will remain within RoHS compliant version
Compliance with EU REACH
UL and cUL approved(No.E214129)
VDE approved (No. 132249)
SEMKO approved
NEMKO approved
DEMKO approved
FIMKO approved
CQC approved
The EL817 series of devices each consist of an infrared emitting diodes, optically coupled to a phototransistor detector. They are packaged in a 4-pin DIP package and available in wide-lead spacing and SMD option.
Applications
Programmable controllers
System appliances, measuring instruments
Telecommunication equipments
Home appliances, such as fan heaters, etc.
Signal transmission between circuits of different potentials and impedances 1 Copyright © 2010, Everlight All Rights Reserved. Release Date :Nov 1, 2016. Issue No: DPC-0000046 Rev.16 www.everlight.com
