Datasheet AD8672 (Analog Devices) - 2
DescriptionPrecision Low Noise, Low Input Bias Current Dual Op Amp
Pages / Page13 / 2 — DLA LAND AND MARITIME. COLUMBUS, OHIO. 16236. V62/16603
File Format / SizePDF / 80 Kb
DLA LAND AND MARITIME COLUMBUS, OHIO 16236 V62/16603
1. SCOPE 1.1 Scope. This drawing documents the general requirements of a precision, very low noise, low input bias current dual operational amplifier microcircuit, with an operating temperature range of -55C to +125C. 1.2 Vendor Item Drawing Administrative Control Number. The manufacturer’s PIN is the item of identification. The vendor item drawing establishes an administrative control number for identifying the item on the engineering documentation: V62/16603 - 01 X E Drawing Device type Case outline Lead finish number (See 1.2.1) (See 1.2.2) (See 1.2.3) 1.2.1 Device type(s). Device type Generic Circuit function 01 AD8672-EP Precision, very low noise, low input bias current dual operational amplifier 1.2.2 Case outline(s). The case outline(s) are as specified herein. Outline letter Number of pins JEDEC PUB 95 Package style X 8 MS-012-AA Plastic small outline surface mount 1.2.3 Lead finishes. The lead finishes are as specified below or other lead finishes as provided by the device manufacturer: Finish designator Material A Hot solder dip B Tin-lead plate C Gold plate D Palladium E Gold flash palladium Z Other 1.3 Absolute maximum ratings. 1/ Supply voltage (VS) .. 36 V Input voltage (VIN) .. -VS to +VS Differential input voltage (VID) .. 0.7 V Output short circuit duration ... Indefinite Power dissipation (PD) ... 0.210 W Storage temperature range (TSTG) .. -65C to +150C Junction temperature range (TJ) .. -65C to +150C Lead temperature range (soldering, 60 seconds) ... +300C Thermal resistance, junction to ambient (JC) .. 43C/W Thermal resistance, junction to ambient (JA) .. 120C/W _______ 1/ Stresses beyond those listed under “absolute maximum rating” may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated under “recommended operating conditions” is not implied. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability.
SIZE CODE IDENT NO. DWG NO.
COLUMBUS, OHIO A 16236 V62/16603
REV PAGE 2
