Datasheet AD8672 (Analog Devices) - 3
DescriptionPrecision Low Noise, Low Input Bias Current Dual Op Amp
Pages / Page13 / 3 — DLA LAND AND MARITIME. COLUMBUS, OHIO. 16236. V62/16603
File Format / SizePDF / 80 Kb
DLA LAND AND MARITIME COLUMBUS, OHIO 16236 V62/16603
1.4 Recommended operating conditions. 2/ Supply voltage range (VS) .. 5 V and 15 V Operating free-air temperature range (TA) ... -55C to +125C 2. APPLICABLE DOCUMENTS JEDEC Solid State Technology Association JEDEC PUB 95 – Registered and Standard Outlines for Semiconductor Devices (Copies of these documents are available online at http:/www.jedec.org or from JEDEC – Solid State Technology Association, 3103 North 10th Street, Suite 240–S, Arlington, VA 22201-2107). 3. REQUIREMENTS 3.1 Marking. Parts shall be permanently and legibly marked with the manufacturer’s part number as shown in 6.3 herein and as follows: A. Manufacturer’s name, CAGE code, or logo B. Pin 1 identifier C. ESDS identification (optional) 3.2 Unit container. The unit container shall be marked with the manufacturer’s part number and with items A and C (if applicable) above. 3.3 Electrical characteristics. The maximum and recommended operating conditions and electrical performance characteristics are as specified in 1.3, 1.4, and table I herein. 3.4 Design, construction, and physical dimension. The design, construction, and physical dimensions are as specified herein. 3.5 Diagrams. 3.5.1 Case outline. The case outline shall be as shown in 1.2.2 and figure 1. 3.5.2 Terminal connections. The terminal connections shall be as shown in figure 2. 2/ Use of this product beyond the manufacturers design rules or stated parameters is done at the user’s risk. The manufacturer and/or distributor maintain no responsibility or liability for product used beyond the stated limits.
SIZE CODE IDENT NO. DWG NO.
COLUMBUS, OHIO A 16236 V62/16603
REV PAGE 3
