Datasheet AD8672 (Analog Devices) - 6
DescriptionPrecision Low Noise, Low Input Bias Current Dual Op Amp
Pages / Page13 / 6 — DLA LAND AND MARITIME. COLUMBUS, OHIO. 16236. V62/16603
File Format / SizePDF / 80 Kb
DLA LAND AND MARITIME COLUMBUS, OHIO 16236 V62/16603
TABLE I. Electrical performance characteristics – Continued. 1/ Test Symbol Conditions Temperature, Device Limits Unit V type S = 5.0 V, VCM = 0 V TA unless otherwise specified Min Max Dynamic performance Slew rate SR RL = 2 k +25C 01 4 typical V/s Settling time tS To 0.1%, 4 V step, G = 1 +25C 01 1.4 typical s To 0.01%, 4 V step, G = 1 5.1 typical Gain bandwidth GBP +25C 01 10 typical MHz product Noise performance Peak to peak noise en p-p 0.1 Hz to 10 Hz +25C 01 100 nV p-p 77 typical Voltage noise density en f = 1 kHz +25C 01 3.8 nV / Hz 2.8 typical Current noise density in f = 1 kHz +25C 01 0.3 typical pA / Hz Channel separation CS f = 1 kHz +25C 01 -130 typical dB f = 10 kHz -105 typical See footnote at end of table.
SIZE CODE IDENT NO. DWG NO.
COLUMBUS, OHIO A 16236 V62/16603
REV PAGE 6
