Datasheet AD8039-EP (Analog Devices)
DescriptionLow Power, 350 MHz Voltage Feedback Amplifier
Pages / Page8 / 1 — Low Power, 350 MHz. Voltage Feedback Amplifier. AD8039-EP. FEATURES. …
File Format / SizePDF / 238 Kb
Low Power, 350 MHz. Voltage Feedback Amplifier. AD8039-EP. FEATURES. FUNCTIONAL BLOCK DIAGRAM
Datasheet AD8039-EP Analog Devices
Low Power, 350 MHz Voltage Feedback Amplifier AD8039-EP FEATURES FUNCTIONAL BLOCK DIAGRAM Low power: 1 mA quiescent current per amplifier AD8039-EP High speed VOUT1 1 8 +VS −3 dB bandwidth (G = +1): 350 MHz –IN1 2 7 VOUT2 Slew rate: 425 V/μs +IN1 3 6 –IN2
1
Low cost
00
–V
7-
S 4 5 +IN2 Low noise
55 09
8 nV/√Hz at 100 kHz
Figure 1. 8-Lead SOIC_N
600 fA/√Hz at 100 kHz Low input bias current: 750 nA maximum 24 Low distortion 21 G = +10 −90 dB SFDR at 1 MHz 18 −65 dB SFDR at 5 MHz Wide supply range: 3 V to 12 V 15 G = +5 Small packaging: 8-lead SOIC 12 ) B Supports defense and aerospace applications (AQEC standard) d ( 9 IN Extended temperature range: −55°C to +105°C G = +2 GA 6 Controlled manufacturing baseline 3 One assembly/test site G = +1 One fabrication site 0 Enhanced product change notification –3 Qualification data available on request –6
02
0.1 1 10 100 1000
-0
57
FREQUENCY (MHz)
95 0 Figure 2. Small Signal Frequency Response for Various Gains,
Battery-powered instrumentation
VOUT = 500 mV p-p, VS = ±5 V
Filters ADC drivers Level shifting Buffering Photo multipliers GENERAL DESCRIPTION
The AD8039-EP dual amplifier is a high speed (350 MHz) voltage The AD8039-EP amplifier has a wide input common-mode range feedback amplifier with an exceptionally low quiescent current of 1 V from either rail and swings to within 1 V of each rail on the of 1.0 mA per amplifier typical (1.5 mA maximum). Despite its output. This amplifier is optimized for driving capacitive loads up low power and low cost, the amplifier provides excellent overall to 20 pF. If driving larger capacitive loads, a small series resistor performance. Additionally, it offers a high slew rate of 425 V/μs is needed to avoid excessive peaking or overshoot. and a low input offset voltage of 3 mV maximum. The AD8039-EP amplifier is available in an 8-lead SOIC package The Analog Devices, Inc., proprietary XFCB process allows low and is rated to work over the extended temperature range of noise operation (8 nV/√Hz and 600 fA/√Hz) at extremely low −55°C to +105°C. quiescent currents. Given its wide supply voltage range (3 V to Additional application and technical information can be found in 12 V), wide bandwidth, and small packaging, the AD8039-EP the AD8038/AD8039 data sheet. amplifier is designed to work in a variety of applications where power and space are at a premium.
Rev. 0 Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. rights of third parties that may result from its use. Specifications subject to change without notice. No license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 www.analog.com Trademarks and registered trademarks are the property of their respective owners. Fax: 781.461.3113 ©2011 Analog Devices, Inc. All rights reserved.
Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS MAXIMUM POWER DISSIPATION OUTPUT SHORT CIRCUIT ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS OUTLINE DIMENSIONS ORDERING GUIDE
