Datasheet AD8574 (Analog Devices) - 6
DescriptionZero-Drift, Single-Supply, RRIO Quad Op Amp
Pages / Page12 / 6 — DLA LAND AND MARITIME. COLUMBUS, OHIO. 16236. V62/12634
File Format / SizePDF / 72 Kb
DLA LAND AND MARITIME COLUMBUS, OHIO 16236 V62/12634
TABLE I. Electrical performance characteristics – Continued. 1/ Test Symbol Conditions Temperature, Device Limits Unit VS = 5 V, VCM = 2.5 , VO = 2.5 V TA type unless otherwise specified Min Max Output characteristics – continued. Short circuit limit ISC +25C 01 25 mA -55C to +125C 40 typical Output current IO +25C 01 30 typical mA -55C to +125C 15 typical Power supply. Power supply rejection PSRR VS = 2.7 V to 5.5 V +25C 01 120 dB ratio -55C to +125C 115 Supply current per ISY VO = 0 V +25C 01 975 A amplifier -55C to +125C 1075 Dynamic performance. Slew rate SR RL = 10 k +25C 01 0.4 typical V/s Overload recovery time +25C 01 0.3 ms Gain bandwidth GBP +25C 01 1.5 typical MHz product Noise performance. Voltage noise enp-p 0 Hz to 10 Hz +25C 01 1.3 typical Vpp 0 Hz to 1 Hz 0.41 typical Voltage noise density en f = 1 kHz +25C 01 51 typical nV / Hz Current noise density in f = 10 Hz +25C 01 2 typical fA / Hz See footnotes at end of table.
SIZE CODE IDENT NO. DWG NO.
COLUMBUS, OHIO A 16236 V62/12634
REV A PAGE 6
