Datasheet OP262-EP (Analog Devices) - 4
Description15 MHz, Rail-to-Rail, Dual Operational Amplifier
Pages / Page12 / 4 — Table 2. Parameter. Symbol. Test Conditions/Comments. Min. Typ. Max. Unit
File Format / SizePDF / 239 Kb
Table 2 Parameter Symbol Test Conditions/Comments Min Typ Max Unit
OP262-EP VS = 3.0 V, VCM = 0 V, TA = 25°C, unless otherwise noted.
Table 2. Parameter Symbol Test Conditions/Comments Min Typ Max Unit
INPUT CHARACTERISTICS Offset Voltage VOS 50 325 μV −55°C ≤ TA ≤ +125°C 1 mV Input Bias Current IB 360 600 nA Input Offset Current IOS ±2.5 ±25 nA Input Voltage Range VCM 0 2 V Common-Mode Rejection CMRR 0 V ≤ VCM ≤ 2.0 V, −55°C ≤ TA ≤ +125°C 70 110 dB Large Signal Voltage Gain AVO RL = 2 kΩ, 0.5 V ≤ VOUT ≤ 2.5 V 20 V/mV RL = 10 kΩ, 0.5 V ≤ VOUT ≤ 2.5 V 20 30 V/mV OUTPUT CHARACTERISTICS Output Voltage Swing High VOH IL = 250 μA 2.95 2.99 V IL= 5 mA 2.85 2.93 V Output Voltage Swing Low VOL IL = 250 μA 14 50 mV IL= 5 mA 66 150 mV POWER SUPPLY Power Supply Rejection Ratio PSRR VS = 2.7 V to 7 V 110 dB −55°C ≤ TA ≤ +125°C 60 dB Supply Current/Amplifier ISY VOUT = 1.5 V 500 650 μA −55°C ≤ TA ≤ +125°C 850 μA DYNAMIC PERFORMANCE Slew Rate SR RL = 10 kΩ 10 V/μs Settling Time tS To 0.1%, AV = −1, VO = 2 V step 575 ns Gain Bandwidth Product GBP 15 MHz Phase Margin φm 59 Degrees NOISE PERFORMANCE Voltage Noise en p-p 0.1 Hz to 10 Hz 0.5 μV p-p Voltage Noise Density en f = 1 kHz 9.5 nV/√Hz Current Noise Density in f = 1 kHz 0.4 pA/√Hz Rev. 0 | Page 4 of 12 Document Outline FEATURES APPLICATIONS PIN CONFIGURATION GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS OUTLINE DIMENSIONS ORDERING GUIDE
