Datasheet OP262-EP (Analog Devices) - 7
Description15 MHz, Rail-to-Rail, Dual Operational Amplifier
Pages / Page12 / 7 — 250. 125. VS = 5V. VS = 5V TA = 25°C. 200. 100. COUNT =. V) µ. 720 OP …
File Format / SizePDF / 239 Kb
250. 125. VS = 5V. VS = 5V TA = 25°C. 200. 100. COUNT =. V) µ. 720 OP AMPS. E ( G A. lifier. 150. m A (. F F. UAN. O T. –200. –140. –80. –20. 160. –75. –50. –25
250 125 VS = 5V VS = 5V TA = 25°C 200 100 COUNT = V) µ 720 OP AMPS E ( G A lifier 150 m A ( F F UAN O T –200 –140 –80 –20 160 –75 –50 –25
OP262-EP TYPICAL PERFORMANCE CHARACTERISTICS
250 125 VS = 5V VS = 5V TA = 25°C 200 100 COUNT = V) µ 720 OP AMPS s) E ( G A lifier T p 150 L 75 m A ( VO Y T IT SE T 100 F F 50 UAN O T Q PU 50 IN 25 0
7
0
0
–200 –140 –80 –20 40 100 160
00 01 6-
–75 –50 –25 0 25 50 75 100 125 150
6-
INPUT OFFSET VOLTAGE (µV)
25
TEMPERATURE (°C)
25 09 09 Figure 2. Input Offset Voltage Distribution Figure 5. Input Offset Voltage vs. Temperature
100 0 VS = 5V VS = 5V TA = 25°C 80 –100 COUNT = 360 OP AMPS A) s) n ( lifier NT p 60 E –200 m A ( Y CURR IT S T 40 IA –300 N A B U UT Q P IN 20 –400 0 –500
1
0.2 0.3 0.5 0.7 0.9 1.1 1.3 1.5
08 0
01 6- 6-
INPUT OFFSET DRIFT, TCV
25
OS (µV,°C)
25
TEMPERATURE (°C)
09 09 Figure 3. Input Offset Voltage Drift (TCV Figure 6. Input Bias Current vs. Temperature OS)
420 15 V V S = 5V S = 5V A) n A) 340 ( n ( NT 10 NT E RE CUR 260 T CURR E S S IA F F B O 5 UT P UT IN 180 INP 100
9
0
2 01
0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0
00
6- 6- 25
COMMON-MODE VOLTAGE (V)
25
TEMPERATURE (°C)
09 09 Figure 4. Input Bias Current vs. Common-Mode Voltage Figure 7. Input Offset Current vs. Temperature Rev. 0 | Page 7 of 12 Document Outline FEATURES APPLICATIONS PIN CONFIGURATION GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS OUTLINE DIMENSIONS ORDERING GUIDE
