Datasheet AD8037 (Analog Devices) - 6
Description | Low Distortion, Wide Bandwidth Voltage Feedback Clamp Amps |
Pages / Page | 13 / 6 — DLA LAND AND MARITIME. COLUMBUS, OHIO. 16236. V62/16612 |
File Format / Size | PDF / 149 Kb |
TABLE I. Electrical performance characteristics – Continued. 1/ Test Symbol Conditions 2/ Temperature, Device Limits Unit TA type Min Max Noise/harmonic performance – continued. Third order intercept 25 MHz +25C 01 41 typical dBm Noise figure RS = 50 +25C 01 14 typical dB Input voltage noise 1 MHz to 200 MHz +25C 01 4.5 typical nV/ Hz Input current noise 1 MHz to 200 MHz +25C 01 2.1 typical pA/ Hz Average equivalent 0.1 MHz to 200 MHz +25C 01 60 typical Vrms integrated input noise voltage Differential gain error RL = 150 +25C 01 0.04 % (3.58 MHz) 0.02 typical Differential phase error RL = 150 +25C 01 0.04 Degree (3.58 MHz) 0.02 typical Phase nonlinearity DC to 100 MHz +25C 01 1.1 typical Degrees Clamp performance Clamp voltage 3/ VCH or VCL +25C 01 3.3 V range 3.9 typical Clamp accuracy 2x overdrive, VCH = 2 V, +25C 01 10 mV VCL = -2 V 3 typical -55C to 105C 20 Clamp nonlinearity 4/ +25C 01 100 typical mV range Clamp input bias VH, VL = 0.5 V +25C 01 70 A current (VH or VL) 50 typical -55C to 105C 90 See footnotes at end of table.
SIZE CODE IDENT NO. DWG NO.
COLUMBUS, OHIO A 16236 V62/16612
REV PAGE 6
