Datasheet AD8037-EP (Analog Devices) - 3
DescriptionLow Distortion, Wide Bandwidth Voltage Feedback Clamp Amp
Pages / Page8 / 3 — Enhanced Product. AD8037-EP. SPECIFICATIONS. Table 1. Parameter Test. …
File Format / SizePDF / 175 Kb
Enhanced Product. AD8037-EP. SPECIFICATIONS. Table 1. Parameter Test. Conditions/Comments. Min. Typ. Max. Unit
Enhanced Product AD8037-EP SPECIFICATIONS Table 1 Parameter Test Conditions/Comments Min Typ Max Unit
link to page 4 link to page 4 link to page 4 link to page 4
VS = ±5 V, RL = 100 Ω, gain = +2, VH, VL open unless otherwise noted.
Table 1. Parameter Test Conditions/Comments Min Typ Max Unit
DYNAMIC PERFORMANCE Bandwidth (−3 dB) Small Signal VOUT ≤ 0.4 V p-p 200 270 MHz Large Signal1 VOUT = 3.5 V p-p 160 190 MHz Bandwidth for 0.1 dB Flatness VOUT ≤ 0.4 V p-p, RF = 274 Ω 130 MHz Slew Rate, Average ± VOUT = 4 V step, 10% to 90% 1100 1500 V/μs Rise/Fall Time VOUT = 0.5 V step, 10% to 90% 1.2 ns VOUT = 4 V step, 10% to 90% 2.2 ns Setting Time To 0.1% VOUT = 2 V step 10 ns To 0.01% VOUT = 2 V step 16 ns NOISE/HARMONIC PERFORMANCE Second Harmonic Distortion 2 V p-p, 20 MHz, RL = 100 Ω −52 −45 dBc RL = 500 Ω −72 −65 dBc Third Harmonic Distortion 2 V p-p, 20 MHz, RL = 100 Ω −70 −63 dBc RL = 500 Ω −80 −73 dBc Third-Order Intercept 25 MHz 41 dBm Noise Figure RS = 50 Ω 14 dB Input Voltage Noise 1 MHz to 200 MHz 4.5 nV/√Hz Input Current Noise 1 MHz to 200 MHz 2.1 pA/√Hz Average Equivalent Integrated Input 0.1 MHz to 200 MHz 60 μV rms Noise Voltage Differential Gain Error (3.58 MHz) RL = 150 Ω 0.02 0.04 % Differential Phase Error (3.58 MHz) RL = 150 Ω 0.02 0.04 Degrees Phase Nonlinearity DC to 100 MHz 1.1 Degrees CLAMP PERFORMANCE Clamp Voltage Range1 VCH or VCL ±3.3 ±3.9 V Clamp Accuracy 2× overdrive, VCH = 2 V, VCL = −2 V ±3 ±10 mV TMIN to TMAX ±20 mV Clamp Nonlinearity Range2 100 mV Clamp Input Bias Current (VH or VL) VH, VL = ±0.5 V ±50 ±70 μA TMIN to TMAX ±90 μA Clamp Input Bandwidth (−3 dB) VCH or VCL = 2 V p-p 180 270 MHz Clamp Overshoot 2× overdrive, VCH or VCL = 2 V p-p 1 5 % Overdrive Recovery 2× overdrive 1.3 ns DC PERFORMANCE3, RL = 150 Ω Input Offset Voltage4 2 7 mV TMIN to TMAX 10 mV Offset Voltage Drift ±10 μV/°C Input Bias Current 3 9 μA TMIN to TMAX 15 μA Input Offset Current 0.1 3 μA TMIN to TMAX 5 μA Common-Mode Rejection Ratio VCM = ±2 V 70 90 dB Open-Loop Gain VOUT = ±2.5 V 54 60 dB TMIN to TMAX 46 dB Rev. 0 | Page 3 of 8 Document Outline FEATURES ENHANCED PRODUCT FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE MAXIMUM POWER DISSIPATION ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS OUTLINE DIMENSIONS ORDERING GUIDE
