Datasheet AD8036 (Analog Devices) - 5
DescriptionUnity Gain Stable - Low Distortion, Wide Bandwidth Voltage Feedback Clamp Amps
Pages / Page11 / 5 — STANDARD. 5962-95597. MICROCIRCUIT DRAWING
File Format / SizePDF / 116 Kb
STANDARD 5962-95597 MICROCIRCUIT DRAWING
TABLE I. Electrical performance characteristics. Conditions 1/ Test Symbol -55°C ≤ TA ≤ +125°C Group A Device Limits 2/ Unit unless otherwise specified subgroups type Min Max Offset voltage VOS 1 01 -7 7 mV 2,3 -8 -8 Positive supply current +IS 1 01 21.5 mA 2,3 25 Negative supply current -IS TA = +25°C 1 01 -21.5 mA Common mode rejection CMRR V ratio CM = 2 V, TA = +25°C 1 01 -0.7 0.7 mV/V Power supply rejection PSRR T ratio A = +25°C 1 01 -3.16 3.16 mV/V Input bias current IIB TA = +25°C 1 01 -10 10 µA Input bias offset current IIBS TA = +25°C 1 01 -3 3 µA IBCH / Clamp bias current 1,2,3 01 -100 100 µA IBCL Clamp high/clamp low VCHE / 1 01 -10 10 mV voltage (VCH/VCL) error VCLE 2,3 -12 12 Measured at –1 V and +1 V, Clamp bias current ±ICL 1 01 -60 60 µA TA = +25°C Measured at 0 V and -2.5 V, Open loop gain ±AOL 1,2,3 01 .251 1000 kV/V measured at 0 V and +2.5 V Positive output swing +VOUT RL = 150 Ω, TA = +25°C 1 01 3.2 5.0 V RL = 50 Ω, TA = +25°C 2.5 5.0 VS = ±3 V, RL = 150 Ω, 1.0 3.0 TA = +25°C Negative output swing -VOUT RL = 150 Ω, TA = +25°C 1 01 -5.0 -3.2 V RL = 50 Ω, TA = +25°C -5.0 -2.5 VS = ±3 V, RL = 150 Ω, -3.0 -1.0 TA = +25°C See footnotes at end of table.
STANDARD
SIZE
5962-95597 MICROCIRCUIT DRAWING A
DLA LAND AND MARITIME REVISION LEVEL SHEET COLUMBUS, OHIO 43218-3990 F 5 DSCC FORM 2234 APR 97 Document Outline DEPARTMENT OF DEFENSE SPECIFICATION DEPARTMENT OF DEFENSE STANDARDS
