Datasheet AD813 (Analog Devices) - 7
DescriptionSingle Supply, Low Power Triple Video Amplifier
Pages / Page11 / 7 — STANDARD. 5962-95596. MICROCIRCUIT DRAWING
File Format / SizePDF / 109 Kb
STANDARD 5962-95596 MICROCIRCUIT DRAWING
Device type 01 Case outline 2 Terminal Terminal symbol number 1 NC 2 DISABLE 1 (See note 1) 3 DISABLE 2 (See note 1) 4 DISABLE 3 (See note 1) 5 NC 6 +VS 7 NC 8 +INPUT 1 9 -INPUT 1 10 OUTPUT 1 11 NC 12 OUTPUT 3 13 -INPUT 3 14 +INPUT 3 15 NC 16 -VS 17 NC 18 +INPUT 2 19 -INPUT 2 20 OUTPUT 2 NC = No connection NOTE: 1. Disable mode operation. Pulling the voltage on any one of the DISABLE pins 4 volts down from the positive supply will put the corresponding amplifier into a disabled, powered down state. In this condition the amplifier's quiescent supply current drops, its output becomes a high impedance, and there is a high level of isolation from input to output. Leaving the DISABLE pins disconnected (floating) will leave the corresponding amplifier operational, in the enabled state. FIGURE 1. Terminal connections.
STANDARD
SIZE
5962-95596 MICROCIRCUIT DRAWING A
DLA LAND AND MARITIME REVISION LEVEL SHEET COLUMBUS, OHIO 43218-3990 C 7 DSCC FORM 2234 APR 97 Document Outline DEPARTMENT OF DEFENSE SPECIFICATION DEPARTMENT OF DEFENSE STANDARDS
