Datasheet AD827 (Analog Devices) - 3
DescriptionHigh Speed, Low Power Dual Op Amp
Pages / Page13 / 3 — STANDARD. 5962-92117. MICROCIRCUIT DRAWING
File Format / SizePDF / 134 Kb
STANDARD 5962-92117 MICROCIRCUIT DRAWING
1.3 Absolute maximum ratings. 1/ Supply voltage (VS) ... ±18 V dc Input common mode voltage range (VCM) ... ±VS Differential input voltage .. ±6.0 V dc Internal power dissipation (PD): Case P ... 1.3 W 2/ Case 2 .. 1.0 W 2/ Storage temperature range .. -65°C to +150°C Lead temperature (soldering, 60 seconds) .. +300°C Junction temperature (TJ) .. +175°C Thermal resistance, junction-to-case (θJC) ... See MIL-STD-1835 Thermal resistance, junction-to-ambient (θJA) ... 110°C/W 1.4 Recommended operating conditions. Supply voltage range (VS) ... ±4.5 V dc to ±15 V dc Ambient operating temperature range (TA) ... -55°C to +125°C 2. APPLICABLE DOCUMENTS 2.1 Government specification, standards, and handbooks. The following specification, standards, and handbooks form a part of this drawing to the extent specified herein. Unless otherwise specified, the issues of these documents are those cited in the solicitation or contract. DEPARTMENT OF DEFENSE SPECIFICATION MIL-PRF-38535 - Integrated Circuits, Manufacturing, General Specification for. DEPARTMENT OF DEFENSE STANDARDS MIL-STD-883 - Test Method Standard Microcircuits. MIL-STD-1835 - Interface Standard Electronic Component Case Outlines. DEPARTMENT OF DEFENSE HANDBOOKS MIL-HDBK-103 - List of Standard Microcircuit Drawings. MIL-HDBK-780 - Standard Microcircuit Drawings. (Copies of these documents are available online at http://quicksearch.dla.mil or from the Standardization Document Order Desk, 700 Robbins Avenue, Building 4D, Philadelphia, PA 19111-5094.) 2.2 Order of precedence. In the event of a conflict between the text of this drawing and the references cited herein, the text of this drawing takes precedence. Nothing in this document, however, supersedes applicable laws and regulations unless a specific exemption has been obtained. ______ 1/ Stresses above the absolute maximum rating may cause permanent damage to the device. Extended operation at the maximum levels may degrade performance and affect reliability. 2/ Maximum internal power dissipation is specified so that the junction temperature does not exceed +175°C. For case P, derate 9 mW/°C for TA > +32°C and for case 2, derate at 6.6 mW/°C for TA > +25°C.
STANDARD
SIZE
5962-92117 MICROCIRCUIT DRAWING A
DLA LAND AND MARITIME REVISION LEVEL SHEET COLUMBUS, OHIO 43218-3990 E 3 DSCC FORM 2234 APR 97 Document Outline DEPARTMENT OF DEFENSE SPECIFICATION DEPARTMENT OF DEFENSE STANDARDS
