Datasheet AD845 (Analog Devices) - 4
DescriptionPrecision, 16 MHz CBFET Op Amp
Pages / Page9 / 4 — STANDARD. 5962-89645. MICROCIRCUIT DRAWING
File Format / SizePDF / 92 Kb
STANDARD 5962-89645 MICROCIRCUIT DRAWING
TABLE I. Electrical performance characteristics. Conditions Test Symbol -55°C ≤ TA ≤ +125°C Group A Device Limits 1/ Unit ±V subgroups type S = ±15 V unless otherwise specified Min Max Input offset voltage VIO VCM = 0 V 1 01 -1 +1 mV 2,3 -2 +2 Power supply rejection PSRR ±V 1 01 88 dB S = ±5 V to ±15 V, ratio TA = +25°C Output voltage swing +VOUT RL ≥ 500 Ω 1 01 12.5 V 2,3 12 -VOUT 1 -12.5 2,3 -12 Quiescent current IQ VOUT = 0 V 1,2,3 01 12 mA Input bias current +IIB VCM = 0 V 2/ 1 01 -2 +2 nA 2,3 -500 +500 -IIB 1 -2 +2 2,3 -500 +500 Common mode input +IVR TA = +25°C 3/ 1 01 +10 V voltage range -IVR -10 Common mode rejection CMRR VCM = ±10 V, TA = +25°C 1 01 86 dB ratio Input offset current IIO VCM = 0 V 4/ 1 01 -0.3 0.3 nA 2,3 -20 20 Input offset voltage +TCVIO TA = +125°C, -55°C 2,3 01 10 µV/°C drift Open loop gain 5/ AOL VOUT = ±10 V, RL = 2 kΩ 4 01 200 V/mV VOUT = ±10 V, 4 100 RL = 500 Ω 5,6 50 See footnotes at end of table.
STANDARD
SIZE
A 5962-89645 MICROCIRCUIT DRAWING
DLA LAND AND MARITIME REVISION LEVEL SHEET COLUMBUS, OHIO 43218-3990 C
4
DSCC FORM 2234 APR 97
