Datasheet AD845 (Analog Devices) - 9
DescriptionPrecision, 16 MHz CBFET Op Amp
Pages / Page9 / 9 — STANDARD. MICROCIRCUIT. DRAWING. BULLETIN. DATE:. 12-12-12. Approved. …
File Format / SizePDF / 92 Kb
STANDARD. MICROCIRCUIT. DRAWING. BULLETIN. DATE:. 12-12-12. Approved. sources. of. supply. for. SMD. 5962-89645. are. listed. below. for. immediate
STANDARD MICROCIRCUIT DRAWING BULLETIN DATE: 12-12-12 Approved sources of supply for SMD 5962-89645 are listed below for immediate
STANDARD MICROCIRCUIT DRAWING BULLETIN DATE: 12-12-12 Approved sources of supply for SMD 5962-89645 are listed below for immediate acquisition information only and shall be added to MIL-HDBK-103 and QML-38535 during the next revision. MIL-HDBK-103 and QML-38535 will be revised to include the addition or deletion of sources. The vendors listed below have agreed to this drawing and a certificate of compliance has been submitted to and accepted by DLA Land and Maritime -VA. This information bulletin is superseded by the next dated revision of MIL-HDBK-103 and QML-38535. DLA Land and Maritime maintains an online database of all current sources of supply at http://www.landandmaritime.dla.mil/Programs/Smcr/. Standard Vendor Vendor microcircuit drawing CAGE similar PIN 1/ number PIN 2/ 5962-8964501PA 24355 AD845SQ/883B 1/ The lead finish shown for each PIN representing a hermetic package is the most readily available from the manufacturer listed for that part. If the desired lead finish is not listed contact the vendor to determine its availability. 2/ Caution. Do not use this number for item acquisition. Items acquired to this number may not satisfy the performance requirements of this drawing. Vendor CAGE Vendor name number and address 24355 Analog Devices Route 1 Industrial Park P.O. Box 9106 Norwood, MA 02062 Point of contact: 804 Woburn Street Wilmington, MA 01887-3462 The information contained herein is disseminated for convenience only and the Government assumes no liability whatsoever for any inaccuracies in the information bulletin.
