Datasheet AD842 (Analog Devices) - 6
DescriptionWideband, High Output Current, Fast Settling Op Amp
Pages / Page12 / 6 — STANDARD. 5962-89642. MICROCIRCUIT DRAWING
File Format / SizePDF / 145 Kb
STANDARD 5962-89642 MICROCIRCUIT DRAWING
TABLE I. Electrical performance characteristics – Continued. Conditions 1/ Test Symbol -55°C ≤ TA ≤ +125°C Group A Device Limits 2/ Unit ±V subgroups type S = ±15 V unless otherwise specified Min Max Power supply rejection +PSRR +VS = 5.0 V to 18 V, 1 01 86 dB ratio -VS = -15 V 2,3 80 -PSRR -VS = -5.0 V to –18 V 1 86 +VS = +15 V 2,3 80 Quiescent power 3/ PC VOUT = 0 V, IOUT = 0 mA 1 01 420 mW consumption 2,3 570 Differential input 4/ RIN VCM = 0 V, TA = +25°C 4 01 50 kΩ resistance Gain bandwidth 4/ GBWP V 4 01 50 MHz OUT = ±100 mV, product f1 = 100 kHz, f2 = 10 MHz, RL = 500 Ω, TA = +25°C Full power 4/ 5/ FPBW V 4 01 4.7 MHz PK = 10 V, RL = 500 Ω, bandwidth TA = +25°C Closed loop stable 4/ CLSG R 4 01 2 V/V L = 500 Ω, CL ≤ 10 pF, gain TA = +25°C Common mode rejection +CMRR ∆VCM = 10 V, +VS = 5.0 V, 1 01 86 dB ratio -VS = -25 V, VOUT = -10 V 2,3 80 -CMRR ∆VCM = -10 V, +VS = 25 V, 1 86 -VS = -5 V, VOUT = 10 V 2,3 80 Settling time 4/ t 9 01 150 ns S AV = -2 V/V, RL = 500 Ω, 10 V step at 0.1 % of the final value, TA = +25°C A 200 V = -2 V/V, RL = 500 Ω, 10 V step at 0.01 % of the fixed value, TA = +25°C See footnotes at end of table.
STANDARD
SIZE
A 5962-89642 MICROCIRCUIT DRAWING
DLA LAND AND MARITIME REVISION LEVEL SHEET COLUMBUS, OHIO 43218-3990 E
6
DSCC FORM 2234 APR 97
