Datasheet MAX4051/A, MAX4052/A, MAX4053/A (Maxim) - 9
Manufacturer | Maxim |
Description | Low-Voltage, CMOS Analog Multiplexers/Switches |
Pages / Page | 19 / 9 — Low-Voltage, CMOS Analog. Multiplexers/Switches. MAX4051/A, MAX4052/A, … |
Revision | 2 |
File Format / Size | PDF / 377 Kb |
Low-Voltage, CMOS Analog. Multiplexers/Switches. MAX4051/A, MAX4052/A, MAX4053/A
Low-Voltage, CMOS Analog Multiplexers/Switches MAX4051/A, MAX4052/A, MAX4053/A __________________________________________Typical Operating Characteristics
(V+ = +5V, V- = -5V, GND = 0V, TA = +25°C, unless otherwise noted.)
ON-RESISTANCE vs. VCOM ON-RESISTANCE vs. VCOM AND TEMPERATURE ON-RESISTANCE vs. VCOM (DUAL SUPPLIES) (DUAL SUPPLIES) (SINGLE SUPPLY)
110 110 300 V+ = 5V V- = 0V 275 100 100 V- = -5V MAX4051/2/3-TOC1 250 MAX4051/2/3-TOC2 MAX4051/2/3-TOC3 90 90 225 V± = ±3V ) 80 T ) 80 A = +125°C ) Ω 200 Ω Ω ( 70 TA = +85°C 175 ON 70 ON V+ = 3V R ONR R 150 60 60 T V± = ±5V A = +25°C 125 50 50 100 V+ = 5V 40 T 40 A = -55°C 75 30 30 50 -5 -4 -3 -2 -1 0 1 2 3 4 5 -5 -4 -3 -2 -1 0 1 2 3 4 5 0 1 2 3 4 5 VCOM (V) VCOM (V) VCOM (V)
ON-RESISTANCE vs. VCOM AND TEMPERATURE OFF-LEAKAGE vs. ON-LEAKAGE vs. (SINGLE SUPPLY) TEMPERATURE TEMPERATURE
180 1000 10,000 V+ = 5V V+ = 5.5V V+ = 5.5V V- = -5.5V V- = -5.5V 160 V- = 0V TA = +125°C 1000 MAX4051/2/3-TOC4 MAX4051/2/3-TOC5 MAX4051/2/3-TOC6 100 140 TA = +85°C ) 100 Ω 120 ( TA = +25°C 10 ON 100 R 10 80 OFF-LEAKAGE (pA) ON-LEAKAGE (pA) TA = -55°C 1 60 1 40 0.1 0.1 0 1 2 3 4 5 -50 -25 0 25 50 75 100 125 -50 -25 0 25 50 75 100 125 VCOM (V) TEMPERATURE (°C) TEMPERATURE (°C)
SUPPLY CURRENT vs. CHARGE INJECTION vs. VCOM TEMPERATURE
5 10 V+ = 5V V- = -5V VEN = VA = 0V, 5V MAX4051/2/3-TOC7 MAX4051/2/3-TOC8 V+ = 5V I+ V- = 0V 0 1 Qj (pC) I- I+, I- (nA) V+ = 5V V- = -5V -5 0.1 -5 -4 -3 -2 -1 0 1 2 3 4 5 -50 -25 0 25 50 75 100 125 VCOM (V) TEMPERATURE (°C)
_______________________________________________________________________________________ 9
