Datasheet SLC (Songle Relay)
ManufacturerSongle Relay
DescriptionSubminature High Power Relay 16A/20A/30A
Pages / Page2 / 1 — SLC. Series. SUBMINATURE. HIGH. POWER. RELAY. 16A/20A/30A. C. US. …
File Format / SizePDF / 3.9 Mb
SLC. Series. SUBMINATURE. HIGH. POWER. RELAY. 16A/20A/30A. C. US. 32.2MAX. AX. Features. E179944. 27.6M. ·Miniature. volume,. PCB. usage. X. A. M. ·Contact
Datasheet SLC Songle Relay
SLC Series SUBMINATURE HIGH POWER RELAY 16A/20A/30A C US 32.2MAX AX Features E179944 27.6M ·Miniature volume, PCB usage X A M ·Contact rating: 16A/20A/30A 8 2 ·Temperature range: +85℃/+105℃ R50056114 CQC CQC08002027666 CQC08002027668 Ordering Information Contact Rating SLC-12VDC-S L-C Contact a rrangment A / B / C Contact resistance 100mΩ A / B / C Contact material Silver alloy:AgCdO、AgSnO2、AgNi Contact arrangment Contact rating 1HP/16A/120VAC 20A/250VAC 30 L0.9W A/250VAC Coil Power Max switching voltage 250VAC S sealed / F dustproof Construction Max switching current 30A 5V / 6V / 9V / 12V 18V / 24V/36V/48V Max switching power 7200VA Coil Voltage Electrical endurance (frequency: 1800 ops/h) 1x10 5ops / 1x10 4 ops Part number 7 endurance Mechanical 1x10 ops (frequency: 18000 ops/h) Characteristics Coil Data ( 20 at ℃) Insulation system B / F Power Voltage Current Resistance dissipation Pick-up Drop-out Max Insulation resistance 100MΩ (500VDC) W VDC mA ± Ω 10% voltage voltage allowable Dielectric Between contacts 2000VAC 1 minute Strength and coil 05 185 27 Leakage current Between open 1500VAC 1 minute 1mA contacts 06 150 40 Operate time(Under nominal voltage) ≤10ms Release time(Under nominal voltage) ≤10ms 09 100 90 Humidity 45% ~85% RH(20℃) 12 75 160 - 0.9W Ambient Temperature 40℃~+85℃/-40℃~+105℃ 75%Max 10%Min 130% ( L ) Functional 98m/s
²
Shock 18 50 380 resistance Destructive 980m/s
²
24 37.5 640 Vibration resistance 10Hz
55Hz 1
5mm ( Double amplitude) Approx 34g 36 25 1440 Weight Construction Sealed 48 18.75 2560 Remark:1)All above data is initial value This product specification only for your reference, we will not notify you if we do any improvement.We reserve all the right for the final explanation Web:www.songle.com www.songlerelay.com Email:sale@songle.com Web:www.songle.com www.songlerelay.com Add.:CW7, Zone A, Far East Industrial Park, Yuyao City, Zhejiang, China i Z p Code:315400 Add.:CW7, Zone A, Far East Industrial Park, Yuyao City, Zhejiang, China Zip Code:315400 Tel.: +86 574 62717777 62762658 62721968 a F x:+86 574 62721978 Document Outline 页 1 页 2
