Datasheet RH1016M (Analog Devices)
DescriptionUltraFast Precision 10ns Comparator
Pages / Page6 / 1 — DESCRIPTION. ABSOLUTE MAXIMUM RATINGS. (Note 1). BURN-IN CIRCUIT. PACKAGE …
File Format / SizePDF / 119 Kb
DESCRIPTION. ABSOLUTE MAXIMUM RATINGS. (Note 1). BURN-IN CIRCUIT. PACKAGE INFORMATION
Datasheet RH1016M Analog Devices
RH1016M UltraFast Precision 10ns Comparator
DESCRIPTION ABSOLUTE MAXIMUM RATINGS (Note 1)
The RH1016 is an UltraFastTM 10ns comparator that inter- Positive Supply Voltage (Note 5)...7V faces directly to TTL/CMOS logic while operating from Negative Supply Voltage ...–7V either ±5V or single 5V supplies. Tight offset voltage Differential Input Voltage (Note 7)...±5V specifi ca tions and high gain allow the RH1016 to be used +IN, –IN and LATCH ENABLE Current (Note 7) ..±10mA in precision applications. Matched complementary outputs Output Current (Continuous) (Note 7) ...±20mA further extend the versatility of this comparator. Operating Temperature Range.. –55°C to 125°C Storage Temperature Range ... –65°C to 150°C A unique output stage provides active drive in both direc- Lead Temperature (Soldering, 10 sec) .. 300°C tions for maximum speed into TTL/CMOS logic or passive loads, yet does not exhibit the large current spikes found L, LT, LTC and LTM are registered trademarks of Linear Technology Corporation. UltraFast is a trademark of Linear Technology Corporation. in conventional output stages. This allows the RH1016 to All other trademarks are the property of their respective owners. remain stable with the outputs in the active region which greatly reduces the problem of output “glitching” when the input signal is slow moving or is low level. The RH1016 has a LATCH pin which will retain input data at the outputs, when held high. Quiescent negative power supply current is only 3mA. This allows the negative supply pin to be driven from virtually any supply voltage with a simple resistive divider. Device performance is not affected by variations in negative supply voltage. The wafer lots are processed to Linear Technology’s in- house Class S fl ow to yield circuits usable in stringent military applications.
BURN-IN CIRCUIT PACKAGE INFORMATION
V4 MONITOR F1 TOP VIEW V4 T.P. V+ 1 10 Q OUT 20Ω 5.11k +IN 2 9 Q OUT 1 10 –IN 3 8 GND 1k 2 9 T.P. T.P. V– 4 7 LATCH ENABLE 3 8 NC 5 6 NC 5.11k 4 7 5 6 W PACKAGE GND POWER 20Ω 10-LEAD CERPAC F2 T.P. V3 V3 MONITOR GND MONITOR RH1016 BURN-IN NOTES: 1. UNLESS OTHERWISE SPECIFIED, COMPONENT TOLERANCES SHALL BE PER MILITARY SPECIFICATION. 2. TJ = 161°C MAXIMUM 3. TC = 139°C MINIMUM 4. TA = 100°C MINIMUM BURN-IN VOLTAGES: V4 = 5.5V TO 6V V3 = –5.5V TO –6V rh1016fa 1
