Datasheet RH1085 (Analog Devices)
Description3A Low Dropout Positive Adjustable Regulator
Pages / Page6 / 1 — DESCRIPTION. ABSOLUTE MAXIMUM RATINGS. (Note 1). PRECONDITIONING. BURN-IN …
File Format / SizePDF / 80 Kb
DESCRIPTION. ABSOLUTE MAXIMUM RATINGS. (Note 1). PRECONDITIONING. BURN-IN CIRCUIT. PACKAGE INFORMATION
Datasheet RH1085 Analog Devices
RH1085 3A Low Dropout Positive Adjustable Regulator
DESCRIPTION ABSOLUTE MAXIMUM RATINGS
The RH1085 positive adjustable regulator is designed to
(Note 1)
provide 3A with higher efficiency than currently available Power Dissipation ... Internally Limited devices. All internal circuitry is designed to operate down Input-to-Output Voltage Differential ..30V to 1V input-to-output differential and the dropout voltage Operating Junction Temperature Range is fully specified as a function of load current. Dropout Control Section ... – 55°C to 150°C is guaranteed at a maximum of 1.5V at maximum output Power Transistor .. –55°C to 200°C current, decreasing at lower load currents. On-chip trim- Storage Temperature Range ...– 65°C to 150°C ming adjusts the output voltage to 1%. Current limit is Lead Temperature (Soldering, 10 sec) .. 300°C also trimmed, minimizing the stress on both the regulator and power source circuitry under overload conditions.
PRECONDITIONING
The RH1085 is pin compatible with older 3-terminal regulators. A 10μF output capacitor is required on these 100% Thermal Limit Burn-In new device. However, this is usually included in most L, LT, LTC, LTM, Linear Technology and the Linear logo are registered trademarks of Linear regulator designs. Technology Corporation. All other trademarks are the property of their respective owners. The wafer lots are processed to Linear Technology Corporation’s in-house Class S flow-to-yield circuits usable in stringent military applications.
BURN-IN CIRCUIT PACKAGE INFORMATION
BOTTOM VIEW VIN RH1085 15V IN OUT 2 ADJ CASE IS OUTPUT 121Ω 1k 1 –15V ADJ CAPACITOR(S) NOT SHOWN RH1085 BI K PACKAGE 2-LEAD TO-3 METAL CAN
FINAL SPECIFICATIONS SUBJECT TO CHANGE Note: For ordering information contact LTC.
rh1085fc 1
