Datasheet LT6376 (Analog Devices) - 8
Description±230V Common Mode Voltage G = 10 Difference Amplifier
Pages / Page30 / 8 — TYPICAL PERFORMANCE CHARACTERISTICS TA = 25°C, VS = ±15V, unless …
TYPICAL PERFORMANCE CHARACTERISTICS TA = 25°C, VS = ±15V, unless otherwise noted. Typical Distribution of Input
TYPICAL PERFORMANCE CHARACTERISTICS TA = 25°C, VS = ±15V, unless otherwise noted Typical Distribution of Input
LT6376
TYPICAL PERFORMANCE CHARACTERISTICS TA = 25°C, VS = ±15V, unless otherwise noted. Typical Distribution of Input Typical Distribution of PSRR Typical Distribution of PSRR Offset Voltage (Input Referred) (Input Referred)
250 300 300 1452 UNITS DIV = 10.3 VS = ±1.65V to ±25V VS = ±1.65V to ±25V 225 FROM FOUR RUNS 270 DIV = 3.1 270 DIV = 8.3
BOTH PACKAGES
200 240 240 1452 UNITS 1452 UNITS 175 210 FROM FOUR RUNS 210 FROM FOUR RUNS
BOTH PACKAGES BOTH PACKAGES
150 180 180 125 150 150 100 120 120 NUMBER OF UNITS 75 NUMBER OF UNITS 90 NUMBER OF UNITS 90 50 60 60 25 30 30 0 0 0 –600 –450 –300 –150 0 150 300 450 600 –5 –4 –3 –2 –1 0 1 2 3 4 5 –10 –8 –6 –4 –2 0 2 4 6 8 10 OFFSET VOLTAGE (µV) PSRR (µV/V) PSRR (µV/V) 6376 G10 6376 G11 6376 G12
Typical Distribution of PSRR Common Mode Voltage Range vs (Input Referred) CMRR vs Frequency Power Supply Voltage
300 120 300 VS = ±1.65V to ±25V 270 DIV = 10.3 250 100 200 240 1452 UNITS TIO (dB) FROM FOUR RUNS 150 210 DIV = 3.1
BOTH PACKAGES
80 100 DIV = 4.3 180 TING RANGE (V) 50 DIV = 5.1 150 60 DIV = 6.3 0 DIV = 7.1 120 –50 DIV = 8.3 NUMBER OF UNITS 40 –100 DIV = 10.3 90 OPAMP IN –150 60 OTT REGION 20 DIV = 3.1 –200 30 DIV = 8.3 COMMON MODE REJECTION RA COMMON MODE OPERA –250 DIV = 10.3 0 0 –300 –15 –12 –9 –6 –3 0 3 6 9 12 15 10 100 1k 10k 100k 1M 10M 0 5 10 15 20 25 30 35 40 45 PSRR (µV/V) FREQUENCY (Hz) POWER SUPPLY VOLTAGE (±V) 6376 G13 6376 G14 6376 G15
Typical Gain Error for Low Supply Typical Gain Error for RL = 10kΩ Typical Gain Error for RL = 2kΩ Voltages (Curves Offset for (Curves Offset for Clarity) (Curves Offset for Clarity) Clarity)
V V S = ±18V S = ±5V, RL = 10kΩ VS = ±18V /DIV) /DIV) /DIV) VS = ±15V V V S = ±5V, RL = 2kΩ S = ±15V VS = ±5V, RL = 1kΩ VS = ±12V VS = ±12V OUTPUT ERROR (2mV OUTPUT ERROR (2mV OUTPUT ERROR (2mV VS = ±10V VS = ±10V VS = ±2.5V, RL = 1kΩ –20 –16 –12 –8 –4 0 4 8 12 16 20 –20 –16 –12 –8 –4 0 4 8 12 16 20 –5 –4 –3 –2 –1 0 1 2 3 4 5 OUTPUT VOLTAGE (V) OUTPUT VOLTAGE (V) OUTPUT VOLTAGE (V) 6376 G16 6376 G17 6376 G18 6376f 8 For more information www.linear.com/LT6376 Document Outline FEATURES DESCRIPTION APPLICATIONS TYPICAL APPLICATION ABSOLUTE MAXIMUM RATINGS PIN CONFIGURATION ORDER INFORMATION E LECTRICAL CHARACTERISTICS TYPICAL PERFORMANCE CHARACTERISTICS PIN FUNCTIONS BLOCK DIAGRAM APPLICATIONS INFORMATION TYPICAL APPLICATIONS PACKAGE DESCRIPTION TYPICAL APPLICATION RELATED PARTS
