Datasheet SR502, SR503, SR504, SR505, SR506, SR508, SR5010 (MCC) - 2
Manufacturer | MCC |
Description | 5 Amp Schottky Barrier Rectifier 50 to 100 Volts |
Pages / Page | 3 / 2 — Micro Commercial Components. 2 of 3 |
File Format / Size | PDF / 167 Kb |
M C C SR502 thru SR5010 TM Figure 1 Figure 2
Typical Forward Characteristics Forward Derating Curve 6 20 SR505-SR506 10 5 6 SR502-SR504 4 4 2 3 SR805-SR5010 Amps Amps 1 2 .6 .4 1 Single Phase, Half Wave .2 60Hz Resistive or Inductive Load 25°C 0 .1 0 50 75 100 125 150 175 .06 °C Average Forward Rectified Current - Amperes versus .04 Ambient Temperature - °C .02 Figure3 Maximum Non-Repetitive Forward Surge Current .01 150 .2 .4 .6 .8 1.0 1.2 Volts 125 Instantaneous Forward Current - Amperes versus Instantaneous Forward Voltage - Volts 100 75 Amps 50 25 0 1 2 4 6 8 10 20 40 60 80 100 Cycles Figure 4 Peak Forward Surge Current - Amperes versus Junction Capacitance Number Of Cycles At 60Hz - Cycles 1000 600 400 200 pF TJ=25° 100 60 40 20 10 .1 .2 .4 1 2 4 10 20 40 100 200 400 100 Volts 0 Junction Capacitance - pF versus www.mccsemi.com Revision: B
2 of 3
2013/01/01
