Datasheet AD5750, AD5750-1, AD5750-2 (Analog Devices) - 7
DescriptionIndustrial Current/Voltage Output Driver with Programmable Ranges
Pages / Page36 / 7 — Data Sheet. AD5750/AD5750-1/AD5750-2. Parameter1. Min. Typ. Max. Unit. …
RevisionF
File Format / SizePDF / 831 Kb
Data Sheet. AD5750/AD5750-1/AD5750-2. Parameter1. Min. Typ. Max. Unit. Test Conditions/Comments
Data Sheet AD5750/AD5750-1/AD5750-2 Parameter1 Min Typ Max Unit Test Conditions/Comments
link to page 25 link to page 7 link to page 7 link to page 7
CURRENT OUTPUT CHARACTERISTICS3 Current Loop Compliance Voltage 0 AVDD − 2.75 V Resistive Load See test conditions/comments column Chosen such that compliance is not exceeded Inductive Load See test conditions/comments column Needs appropriate capacitor at higher inductance values; see the Driving Inductive Loads section Settling Time 4 mA to 20 mA, Full-Scale Step 8.5 µs 250 Ω load 4 mA to 20 mA, 120 µA Step 1.2 µs 250 Ω load DC PSRR 1 µA/V Output Impedance 130 MΩ Leakage Current −12 +12 nA Output disabled; leakage to ground VOUT/VSENSE− Error 0.9994 1.0006 Gain Error in VOUT voltage due to changes in VSENSE−; specified as gain, for example, if VSENSE− moves by 1 V, VOUT moves by 0.9994 V DIGITAL INPUT JEDEC compliant Input High Voltage, VIH 2 V Input Low Voltage, VIL 0.8 V Input Current −1 +1 µA Per pin Pin Capacitance 5 pF Per pin DIGITAL OUTPUTS3 FAULT, IFAULT, TEMP, VFAULT Output Low Voltage, VOL 0.4 V 10 kΩ pull-up resistor to DVCC 0.6 V At 2.5 mA Output High Voltage, VOH 3.6 V 10 kΩ pull-up resistor to DVCC SDO Output Low Voltage, VOL 0.5 0.5 V Sinking 200 µA Output High Voltage, VOH DVCC − 0.5 DVCC − 0.5 V Sourcing 200 µA High Impedance Output Capacitance 3 pF High Impedance Leakage Current −1 +1 µA POWER REQUIREMENTS AVDD 12 24 V ±10% AVSS −12 −24 V ±10% DVCC Input Voltage 2.7 5.5 V AIDD 4.4 5.6 mA Output unloaded, output disabled, R3, R2, R1, R0 = 0, 1, 0, 1; RSET = 0 5.2 6.2 mA Current output enabled 5.2 6.2 mA Voltage output enabled AISS 2.0 2.5 mA Output unloaded, output disabled, R3, R2, R1, R0 = 0, 1, 0, 1; RSET = 0, AD5750 and AD5750-1 2.0 3.5 mA AD5750-2 2.5 3 mA Current output enabled 2.5 3 mA Voltage output enabled DICC 0.3 1 mA VIH = DVCC, VIL = GND Power Dissipation 108 mW AVDD/AVSS = ±24 V, outputs unloaded 1 Temperature range: −40°C to +105°C; typical at +25°C. 2 Specification includes gain and offset errors over temperature and drift after 1000 hours, TA = 125°C. 3 Guaranteed by characterization, but not production tested. Rev. F | Page 7 of 36 Document Outline Features Applications General Description Table of Contents Revision History Functional Block Diagram Specifications Timing Characteristics Timing Diagrams Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Voltage Output Current Output Terminology Theory of Operation Software Mode Current Output Architecture Driving Inductive Loads Voltage Output Amplifier Driving Large Capacitive Loads Power-On State of AD5750/AD5750-1/AD5750-2 Default Registers at Power-On Reset Function OUTEN Software Control Input Shift Register Status Bit Read Operation Hardware Control Transfer Function Detailed Description of Features Output Fault Alert—Software Mode Output Fault Alert—Hardware Mode Voltage Output Short-Circuit Protection Asynchronous Clear (CLEAR) External Current Setting Resistor Programmable Overrange Modes Packet Error Checking Applications Information Transient Voltage Protection Thermal Considerations Layout Guidelines Galvanically Isolated Interface Microprocessor Interfacing Outline Dimensions Ordering Guide
