Datasheet HMC631LP3, 631LP3E (Analog Devices) - 2
DescriptionGaAs HBT Vector Modulator 1.8 -2.7 GHz
Pages / Page8 / 2 — HMC631LP3 / 631LP3E. GaAs HBT VECTOR. MODULATOR 1.8 - 2.7 MHz. Maximum …
File Format / SizePDF / 848 Kb
HMC631LP3 / 631LP3E. GaAs HBT VECTOR. MODULATOR 1.8 - 2.7 MHz. Maximum Gain vs. Temperature. Maximum Gain vs. Supply Voltage
HMC631LP3 / 631LP3E GaAs HBT VECTOR MODULATOR 1.8 - 2.7 MHz Maximum Gain vs Temperature Maximum Gain vs Supply Voltage
HMC631LP3 / 631LP3E
v00.1007
GaAs HBT VECTOR MODULATOR 1.8 - 2.7 MHz Maximum Gain vs. Temperature Maximum Gain vs. Supply Voltage
0 0 -2 -2 -4 -4 -6 -6 -8 -8 -10 -10 GAIN (dB) -12 GAIN (dB) -12 -14 +25C -14 7.6V +85C 8.0V -16 -40C -16 8.4V -18 -18 -20 -20 10 1.7 1.8 1.9 2 2.1 2.2 2.3 2.4 2.5 2.6 2.7 2.8 1.7 1.8 1.9 2 2.1 2.2 2.3 2.4 2.5 2.6 2.7 2.8 FREQUENCY (GHz) FREQUENCY (GHz) T
Phase vs. Phase Settings @ F= 2 GHz Gain vs. Phase Settings @ F= 2 GHz vs. Various Gain Settings
0 360 - SM 315 S -10 R 270 MAX -5 dB -10 dB O 225 -20 -20 dB T 180 A GAIN (dB) -30 135 L PHASE (DEGREES) U 90 -40 MAX -10 dB -5 dB -20 dB 45 -50 0 0 45 90 135 180 225 270 315 360 0 45 90 135 180 225 270 315 360 MOD PHASE SETTING (DEGREES) PHASE SETTING (DEGREES)
Input Return Loss vs. Temperature Output Return Loss vs. Temperature
0 0 +25C -5 -5 +85C -40C -10 -10 +25C -15 +85C -15 -40C RETURN LOSS (dB) RETURN LOSS (dB) -20 -20 -25 -25 1.7 1.8 1.9 2 2.1 2.2 2.3 2.4 2.5 2.6 2.7 2.8 1.7 1.8 1.9 2 2.1 2.2 2.3 2.4 2.5 2.6 2.7 2.8 FREQUENCY (GHz) FREQUENCY (GHz) Information furnishe F d o b r pr y Analic o e g , D d evi e ce li s v i e s brey li , a eve n d t d to p o be acc luac rat e o e an r d d rele ia rs ble , p . Hole we a ves r, e n c o ont Fo ac r p t H rice i, tt dit ele M iveryic , r a owa nd to ve C plac o e r o p rdo e r r at s: i Ao n n al:og Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other 20 Alpha Road, Chelmsford, MA 01824 Phone One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 rights of third parties that may result from its use. Specifications subject to change without notice. No : 978-250-3343 Fax: 978-250-3373 license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Phone: 781-329-4700 • Order online at www.analog.com
10 - 59
Order On Trademarks and registered trademarks are the property of their respective owners. -line at www.hi A tt p i pte lic.c atiom n Support: Phone: 1-800-ANALOG-D
