Datasheet HMC631LP3, 631LP3E (Analog Devices) - 3
DescriptionGaAs HBT Vector Modulator 1.8 -2.7 GHz
Pages / Page8 / 3 — HMC631LP3 / 631LP3E. GaAs HBT VECTOR. MODULATOR 1.8 - 2.7 MHz. Output …
File Format / SizePDF / 848 Kb
HMC631LP3 / 631LP3E. GaAs HBT VECTOR. MODULATOR 1.8 - 2.7 MHz. Output Noise vs. Output Noise vs. Temperature
HMC631LP3 / 631LP3E GaAs HBT VECTOR MODULATOR 1.8 - 2.7 MHz Output Noise vs Output Noise vs Temperature
HMC631LP3 / 631LP3E
v00.1007
GaAs HBT VECTOR MODULATOR 1.8 - 2.7 MHz Output Noise vs. Output Noise vs. Temperature Phase Settings @ F= 2 GHz
-160 -150 -152 -154 -162 -156 -158 -160 -164 -162 -164 -166 -166 -168 NOISE (dBm/Hz) NOISE (dBm/Hz) -170 -172 +25C -168 +85C -174 -40C 10 -176 -178 -170 -180 1.7 1.8 1.9 2 2.1 2.2 2.3 2.4 2.5 2.6 2.7 2.8 0 45 90 135 180 225 270 315 360 FREQUENCY (GHz) PHASE SETTING (DEGREES) T
Input P1dB vs. Temperature Input IP3 vs. Temperature
- SM 22 44 S 42 R 20 O 40 T 38 18 A 36 L +25C 16 IP3 (dBm) P1dB (dBm) +85C U 34 -40C 32 +25C 14 +85C 30 -40C MOD 12 28 1.7 1.8 1.9 2 2.1 2.2 2.3 2.4 2.5 2.6 2.7 2.8 1.8 1.9 2 2.1 2.2 2.3 2.4 FREQUENCY (GHz) FREQUENCY (GHz)
Group Delay Linear Gain vs. Phase Setting
800 90 1 120 60 750 0.8 0.6 30 700 0.4 0.2 650 0 0 600 GROUP DELAY (ps) 550 MAGNITUDE G/Gmax 210 330 500 1.7 1.8 1.9 2 2.1 2.2 2.3 2.4 2.5 2.6 2.7 2.8 240 300 FREQUENCY (GHz) 270 Information furnishe F d o b r pr y Analic o e g , D d evi e ce li s v i e s brey li , a eve n d t d to p o be acc luac rat e o e an r d d rele ia rs ble , p . Hole we a ves r, e n c o ont Fo ac r p t H rice i, tt dit ele M iveryic , r a owa nd to ve C plac o e r o p rdo e r r at s: i Ao n n al:og Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other
10 - 60
20 Alpha Road, Chelmsford, MA 01824 Phone One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 rights of third parties that may result from its use. Specifications subject to change without notice. No : 978-250-3343 Fax: 978-250-3373 license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Phone: 781-329-4700 • Order online at www.analog.com Order On Trademarks and registered trademarks are the property of their respective owners. -line at www.hi A tt p i pte lic.c atiom n Support: Phone: 1-800-ANALOG-D
