Datasheet HMC630LP3, 630LP3E (Analog Devices) - 2
DescriptionGaAs HBT Vector Modulator 700 -1000 MHz
Pages / Page8 / 2 — HMC630LP3 / 630LP3E. GaAs HBT VECTOR. MODULATOR 700 - 1000 MHz. Maximum …
File Format / SizePDF / 827 Kb
HMC630LP3 / 630LP3E. GaAs HBT VECTOR. MODULATOR 700 - 1000 MHz. Maximum Gain vs. Temperature. Maximum Gain vs. Supply Voltage
HMC630LP3 / 630LP3E GaAs HBT VECTOR MODULATOR 700 - 1000 MHz Maximum Gain vs Temperature Maximum Gain vs Supply Voltage
HMC630LP3 / 630LP3E
v00.1007
GaAs HBT VECTOR MODULATOR 700 - 1000 MHz Maximum Gain vs. Temperature Maximum Gain vs. Supply Voltage
0 0 -2 -2 -4 -4 -6 -6 -8 -8 -10 -10 GAIN (dB) -12 GAIN (dB) -12 -14 +25C -14 7.6V +85C 8.0V -16 -40C -16 8.4V -18 -18 -20 -20 10 0.6 0.7 0.8 0.9 1 1.1 0.6 0.7 0.8 0.9 1 1.1 FREQUENCY (GHz) FREQUENCY (GHz) T
Phase vs. Phase Settings @ F= 900 MHz Gain vs. Phase Settings @ F= 900 MHz vs. Various Gain Settings
0 360 - SM 315 S -10 R 270 O 225 -20 T 180 A GAIN (dB) -30 135 L MAX -5dB PHASE (DEGREES) -10dB U 90 -20dB -40 MAX -10dB -5dB -20dB 45 -50 0 0 45 90 135 180 225 270 315 360 0 45 90 135 180 225 270 315 360 MOD PHASE SETTING (DEGREES) PHASE SETTING (DEGREES)
Input Return Loss vs. Temperature Output Return Loss vs. Temperature
0 0 -5 -5 +25C +85C -10 -10 -40C -15 -15 -20 -20 +25C +85C -25 -40C RETURN LOSS (dB) RETURN LOSS (dB) -25 -30 -30 -35 -35 0.6 0.7 0.8 0.9 1 1.1 0.6 0.7 0.8 0.9 1 1.1 FREQUENCY (GHz) FREQUENCY (GHz) Information furnishe F d o b r pr y Analic o e g , D d evi e ce li s v i e s brey li , a eve n d t d to p o be acc luac rat e o e an r d d rele ia rs ble , p . Hole we a ves r, e n c o ont Fo ac r p t H rice i, tt dit ele M iveryic , r a owa nd to ve C plac o e r o p rdo e r r at s: i Ao n n al:og Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other 20 Alpha Road, Chelmsford, MA 01824 Phone One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 rights of third parties that may result from its use. Specifications subject to change without notice. No : 978-250-3343 Fax: 978-250-3373 license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Phone: 781-329-4700 • Order online at www.analog.com
10 - 51
Order On Trademarks and registered trademarks are the property of their respective owners. -line at www.hi A tt p i pte lic.c atiom n Support: Phone: 1-800-ANALOG-D
