Datasheet HMC630LP3, 630LP3E (Analog Devices) - 3
DescriptionGaAs HBT Vector Modulator 700 -1000 MHz
Pages / Page8 / 3 — HMC630LP3 / 630LP3E. GaAs HBT VECTOR. MODULATOR 700 - 1000 MHz. Output …
File Format / SizePDF / 827 Kb
HMC630LP3 / 630LP3E. GaAs HBT VECTOR. MODULATOR 700 - 1000 MHz. Output Noise vs. Output Noise vs. Temperature
HMC630LP3 / 630LP3E GaAs HBT VECTOR MODULATOR 700 - 1000 MHz Output Noise vs Output Noise vs Temperature
HMC630LP3 / 630LP3E
v00.1007
GaAs HBT VECTOR MODULATOR 700 - 1000 MHz Output Noise vs. Output Noise vs. Temperature Phase Settings @ F= 900 MHz
-160 -150 -152 -154 -162 -156 -158 -160 -164 -162 -164 -166 -166 -168 NOISE (dBm/Hz) NOISE (dBm/Hz) -170 -172 +25C -168 +85C -174 -40C 10 -176 -178 -170 -180 0.7 0.8 0.9 1 0 45 90 135 180 225 270 315 360 FREQUENCY (GHz) PHASE SETTING (DEGREES) T
Input P1dB vs. Temperature Input IP3 vs. Temperature
- SM 22 38 S R 20 36 O 18 T 34 A 16 L IP3 (dBm) P1dB (dBm) 32 U 14 +25C +85C +25C 30 +85C 12 -40C -40C MOD 10 28 0.6 0.7 0.8 0.9 1 1.1 0.7 0.8 0.9 1 FREQUENCY (GHz) FREQUENCY (GHz)
Group Delay Linear Gain vs. Phase Setting
1300 90 1 120 60 1250 0.8 1200 0.6 30 1150 0.4 0.2 1100 0 0 1050 GROUP DELAY (ps) 1000 MAGNITUDE G/Gmax 950 210 330 900 0.6 0.7 0.8 0.9 1 1.1 240 300 FREQUENCY (GHz) 270 Information furnishe F d o b r pr y Analic o e g , D d evi e ce li s v i e s brey li , a eve n d t d to p o be acc luac rat e o e an r d d rele ia rs ble , p . Hole we a ves r, e n c o ont Fo ac r p t H rice i, tt dit ele M iveryic , r a owa nd to ve C plac o e r o p rdo e r r at s: i Ao n n al:og Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other
10 - 52
20 Alpha Road, Chelmsford, MA 01824 Phone One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 rights of third parties that may result from its use. Specifications subject to change without notice. No : 978-250-3343 Fax: 978-250-3373 license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Phone: 781-329-4700 • Order online at www.analog.com Order On Trademarks and registered trademarks are the property of their respective owners. -line at www.hi A tt p i pte lic.c atiom n Support: Phone: 1-800-ANALOG-D
