Datasheet HMC500LP3, 500LP3E (Analog Devices)
DescriptionGaAs HBT Vector Modulator SMT, 1.8 - 2.2 GHz
Pages / Page8 / 1 — HMC500LP3 / 500LP3E. GaAs HBT VECTOR. MODULATOR 1.8 - 2.2 GHz. Typical …
File Format / SizePDF / 398 Kb
HMC500LP3 / 500LP3E. GaAs HBT VECTOR. MODULATOR 1.8 - 2.2 GHz. Typical Applications. Features. Functional Diagram
Datasheet HMC500LP3, 500LP3E Analog Devices
HMC500LP3 / 500LP3E
v02.1109
GaAs HBT VECTOR MODULATOR 1.8 - 2.2 GHz Typical Applications Features
The HMC500LP3(E) is ideal for: 360° of Continuous Phase Control • Wireless Infrastructure HPA & Continuous Gain Control: 40 dB MCPA Error Correction -162 dBm/Hz Output Noise Floor • Pre-Distortion or Feed-Forward Linearization Input IP3: +33 dBm • PCS, GSM and W-CDMA Systems 16 Lead 3x3 mm SMT Package: 9mm2 • Beam Forming or RF Cancellation Circuits
10 The HMC500LP3(E) is a high dynamic range Vector Modulator RFICs which are targeted for RF predistortion and feed-forward cancellation circuits, T as well as RF cancellation and beam forming amp- litude/phase correction circuits. The I & Q ports of the HMC500LP3(E) can be used to continuously vary - SM the phase and amplitude of RF signals by up to 360 R degrees and 40 dB respectively, while supporting a O 3 dB modulation bandwidth of 150 MHz. With an in- T put IP3 of +33 dBm and input noise fl oor of -152 dBm/ C Hz (at -10 dB maximum gain setting), the input IP3/ E noise fl oor ratio is 185 dB. - V S R O
Electrical Specifi cations, T = +25° C, Vcc = +8V A
T Parameter Min. Typ. Max. Units A L Frequency Range 1.8 - 2.2 GHz U Maximum Gain -14 -10 dB Gain Variation Over Temperature 0.012 0.02 dB / °C Gain Flatness Across Any 60 MHz Bandwidth 0.15 dB Gain Range 40 dB MOD Input Return Loss 17 dB Output Return Loss 15 dB Input Power for 1dB Compression (P1dB) 13 16 dBm Input Third Order Intercept (IP3) 33 dBm Output Noise -162 dBm/Hz Control Port Bandwidth (-3 dB) 150 MHz Control Port Impedance 1.45k Ohms Control Port Capacitance 0.22 pF Control Voltage Range +0.5 to +2.5 Vdc Group Delay Over 60 MHz Bandwidth 20 ps Supply Current (Icq) 90 mA Unless otherwise noted, measurements are made @ max. gain setting and 45˚ phase setting. See application circuit for details. Information furnishe F d obr pr y An i al c o e g ,D d evi e ce lis vie s r beyli, a eve n d t d to p o be acclac urat e o e an r d d releiars ble , p . Hole we a vesr, en c o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other ontact Hittite Microwave Corporation: One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 20 Alpha Road, Chelmsford, MA 01824 Phone rights of third parties that may result from its use. Specifications subject to change without notice. No : 9P7h8 o - n 25 e: 7 0- 81 3 - 3 2 4 9- 3 F 470 ax: 9 0 • Ord 7 e 8 r o -n25 lin 0- e a 3 t 373
10 - 34
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com Order On Trademarks and registered trademarks are the property of their respective owners. -line at www.hi A tt p ipte lic .c ati o o m n Support: Phone: 1-800-ANALOG-D
