Datasheet HMC247 (Analog Devices)
Description400° Analog Phase Shifter Chip, 5 - 18 GHz
Pages / Page6 / 1 — HMC247. 400° ANALOG PHASE SHIFTER. 5 - 18 GHz. Typical Applications. …
File Format / SizePDF / 332 Kb
HMC247. 400° ANALOG PHASE SHIFTER. 5 - 18 GHz. Typical Applications. Features. Functional Diagram. General Description
Datasheet HMC247 Analog Devices
HMC247
v03.0809
400° ANALOG PHASE SHIFTER 5 - 18 GHz Typical Applications Features
The HMC247 is ideal for: Wide Bandwidth: 5 - 18 GHz • Fiber Optics Phase Shift: >400° 3 Single Positive Voltage Control • Military Small Size: 2.3 x 1.6 x 0.1 mm • Test Equipment IP
H The HMC247 is an Analog Phase Shifter die which is controlled via an analog control voltage from 0 to +10V. The HMC247 provides a continuously variable phase shift of 0 to 300 degrees at 9 GHz, and 0 to OG - C 100 degrees at 18 GHz, with consistent insertion loss L versus phase shift. The phase shift is monotonic with A respect to the control voltage. The control port has a N modulation bandwidth of 50 MHz. The low insertion loss and compact size enable this part to be used in a wide range of applications, including the phase S - A adjustment of clocks in fi ber optic systems and test R equipment. All data is measured with the chip in a 50 E T ohm test fi xture, connected via 0.076 mm (3 mil) ribbon bonds of minimal length <0.31 mm (<12 mils). IF H E S S A H P
Electrical Specifi cations, T = +25° C, 50 Ohm System A
Parameter Frequency (GHz) Min. Typ. Max. Units 5 - 10 GHz 180 400 degrees Phase Shift Range: 10 - 13 GHz 135 200 degrees 13 - 18 GHz 45 120 degrees 5 - 10 GHz 8 12 dB Insertion Loss 10 - 18 GHz 4 7 dB Return Loss (Input and Output) 5 - 18 GHz 8 dB Control Voltage Range 5 - 18 GHz 0 - 10 Volt Modulation Bandwidth 5 - 18 GHz 50 MHz Phase Voltage Sensitivity 5 - 18 GHz 40 deg /Volt Insertion Phase Temperature Sensitivity 5 - 18 GHz 0.5 deg /°C Information furnish F e o d r pri by An ce, de alog Devic leis vie s rby eli, a eve nd to pla d to be accur ce o ate an r d der relia s ble , pl . Ho ease co wever, no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other ntact Hittite Microwave Corporation: One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 rights of third parties that may result from its use. Specifications subject to change without notice. No
3 - 2
20 Alpha Road, Chelmsford, MA 01824 Phone: 978 Phon -e25 : 7 0 81 - - 3 3 3 29 4 - 3 F 470 ax 0 • O : 978 rder o - nl 25 in 0 e a - t 33 ww 73 license is granted by implication or otherwise under any patent or patent rights of Analog Devices. w.analog.com Order On- Trademarks and registered trademarks are the property of their respective owners. line at www.hi A tptipte.co licatio m n Support: Phone: 1-800-ANALOG-D
